Rancho 9000XL Question
Old 06-03-2009, 09:46 PM
Idaho Guy's Avatar
Sorry if this is a stupid question. A Google search, a search of this site, and a search of Rancho's site didn't turn up an answer to my question.
Regarding Rancho 9000XL adjustable shocks...do they provide resistance to both compression *and* expansion? I've heard that some of the gas charged shocks only provide resistance to compression. If that's true of the 9000XL's, they're not what I'm looking for. Thanks.
Old 06-03-2009, 10:11 PM
SlowJeep's Avatar
As far as I know all (usable) shocks provide rebound damping.
I got one of the first sets of RS9000XLs for my 2006 and have over 35,000 miles on them. Been very happy with them.
Old 06-03-2009, 10:23 PM
bansh-eman's Avatar
Shouldn't your rebound be controlled by your springs more then the valving?
Old 06-03-2009, 11:01 PM
oldblues's Avatar
hi
i have ranchos on the rear and am happy camper !
Old 06-04-2009, 05:55 AM
stroker101's Avatar
the shock dampens forces in both directions. it has different valving characteristics for compression and rebound. some shocks may be valved the same in both directions
Old 06-04-2009, 07:51 AM
SlowJeep's Avatar
Exactly and a shock valved the same in both directions is called a steering damper.
Old 06-04-2009, 05:55 PM
"California Style"
mega-engr's Avatar
Spring support the load. Shock control it and do the damping.
I wonder if the adjustability is just from compression as well. Most like it is.
Old 06-04-2009, 06:34 PM
SlowJeep's Avatar
Seat of the pants tells me that the adjustments control compression and rebound an equal amount. Unladen I run 4 in the front and 0 in back, when loaded I run a 6 in front and 4 or 5 in back.
Old 06-04-2009, 06:40 PM
"California Style"
mega-engr's Avatar
Actually, that would probably make the most sense as they are probably not independent circuits with separate valving and control.
Not much of a difference than a steering stabilizer (or damper) then... Other that the actual amount of damping being accomplished.
Old 06-04-2009, 08:59 PM
stroker101's Avatar
QUOTE:
Rancho RS9000X
Dial-in the ride comfort of your truck or SUV with a simple **** turn, or even push of a remote. Rancho RS9000X Shocks boast 9 levels of compression and rebound damping, giving you the most versatile driving experience possible.
At the base of each Rancho RS9000X Shock is an easy-turn dial. Start at position 1 for smooth highway cruising. Hit the middle at spot 5 for a balanced everyday mix of pavement, rough road and trail driving. Or, crank your RS9000X Shocks up to 9 for responsive dampening that's ready to rock off-road. They're quick to adjust manually; or, change front and rear on the fly with Rancho's in-cab remote system.
Rancho RS9000XL:
Bigger shocks for todays bigger trucks!
The RS9000XL are a massive new shock series that meet all the demands of recreational enthusiast and are perfect for hauling or towing heavy trailers, boats, ATV's or campers. Rancho’s RS9000XL shock absorbers feature adjustable damping with either a 2.75-, 2.38- or 2.18-in. diameter reserve tube, delivering greater oil capacity. A massive shock body allows the RS9000XL to run more consistent & cooler even under the most demanding towing conditions, enhancing performance and durability, and is constructed with a larger than typical 18-mm diameter chromed piston rod (select applications).
Bersaglieri
10-08-2012 08:01 AM
jiggerman78
05-20-2010 04:27 PM
gus's 03
07-11-2007 09:40 PM
Mexstan
11-10-2005 08:19 PM
jlipskoc
09-28-2005 04:38 PM
Quick Reply: Rancho 9000XL Question
