Quick Tow Haul mode question
Old 05-12-2007, 02:57 PM
wreedCTD's Avatar
I have been running in Tow Haul the last couple days at speeds under 40 around my house. I have noticed when slowing down from say 45mph coming to a stop sign, the tranny will downshift very firm. I kind bumps you foward.
Is this normal?
Thanks.
Old 05-12-2007, 03:38 PM
coparam4x4's Avatar
Yep that's normal.
Old 05-12-2007, 03:39 PM
wreedCTD's Avatar
what is it doing exactly?
Old 05-12-2007, 03:42 PM
carharttfarmer's Avatar
unlocking down shifting locking back up mines does it all the time cuz of the jake
Old 05-12-2007, 03:43 PM
wreedCTD's Avatar
does the TC stayed locked more in Tow Haul? Is that what you are saying?
Old 05-12-2007, 03:45 PM
$oC@l CTD's Avatar
Yes...put the truck in drive and just ease on the throttle and drive normal on up to about 60...notice that the TC will lock with the tow/haul mode on at around 30mph if you don't have it to the floor and without tow/haul mode on, it won't lock until around 50+/-.
My truck downshifts rough in tow/haul as well...you're fine.
Old 05-12-2007, 04:41 PM
cbrahs's Avatar
think of it like the tranny is manually downshifting to slow you down. It is normal. I use it when coming off the freeway.
Old 05-13-2007, 01:25 AM
LVTony's Avatar
I always drive in Tow Haul. I wish the selector only had T/H and O/D off. I never use the regular mode. T/H is a little rough downshifting.
It seemed a little rough upshifting when more skinny peddle was used than less, but now with Smarty it seems like upshifting is smoother. Has anybody else noticed that? Of course, I'm only running on #1 w/Smarty, so higher levels on a non-stock tranny would probably be different...
Old 05-13-2007, 03:04 AM
bigredBCS's Avatar
t/h on, makes lots of smoke at 30mphh!!!!!!!!!
Old 05-13-2007, 08:38 AM
jrussell's Avatar
T/H holds the gears too long for my liking with an empty truck. It won't upshift when you're just cruising down the road around 40mph and holds the RPM's higher than they need to be for cruising empty.
I've started using 2nd and 3rd (O/D locked out) when driving on city streets at slower speeds. It shifts normally and locks the TC at 30mph in 2nd and ~40mph in 3rd. This way I can still drive around with the TC locked but don't have to deal with the hard shifts and high RPM's of T/H.
Old 05-13-2007, 08:39 AM
donnee's Avatar
I am curious, at what speed would be safest to do this??
I do this but usually under 50.
Turbocrazy
03-06-2013 07:06 PM
Hoss
10-31-2012 08:50 PM
wellmax
07-07-2011 02:59 PM
KenandCarolW
06-28-2004 11:56 PM
tony
13
01-25-2004 04:10 PM
Quick Reply: Quick Tow Haul mode question
