Quick ?
Quick ?
My Chassis wiring harness is all hacked up And I found someone who has one off a ext cab long bed truck will this work on my dually? Did they make any big changes on the second gens with the harness? Your help would be great
I've ran circles around the internet and havn't found there to be an issue. The harness is also coming off of a 98.5-99 truck so I should be good. Also, I 'll ask this: My fuel gauge goes to empty at about 3/4 of a tank and comes back up. Is the sending unit going bad?
The senders are known to fail. Especially if the high speed big rig pumps are used during fill-ups. They lie in the path of the fill hose and take a beating supposedly. This can lead to early failures.
Kurt
Kurt
I just replaced the sender in mine yesterday. It did not appear to me to be in the fuel fill path at all. It is on the opposite side and the float goes forward and away from the fill path. It may be different on the earlier models as it appears they have a different sender.
Russ may be right, I'm going off previous threads I have read. Most fuel gauge problems were from the sender, not the gauge or related wiring.
Kurt
Kurt
HorseHauler
13
03-12-2006 11:48 AM
soundbrz
11-19-2002 11:36 PM
