quick question
Old Dec 4, 2008 | 07:14 AM
89f150's Avatar
quick question
Ok well I have 6x16s and the pump all the way up pretty much everything else stock and I was wonder what my truck is doing. When I floor It or anything over half throttle pretty mUch it seems like its flooding or bogging? Or kinda a miss and runs crappy? Any no what that could be? And if I get better fuel supply and hx40 would that fix my problem? If not what will?
Jon
Old Dec 4, 2008 | 07:52 AM
archer39's Avatar
sounds like your out of fuel. you would benefit from upgrading your fuel system.
Old Dec 4, 2008 | 07:59 AM
apwatson50's Avatar
Yeah if you're still running the stock LP then it sounds like the pump is starving for fuel and loosing timing. Get your walbro pump installed and i'm sure you'll gain like 300hp and 900ftlbs! haha But seriously it should fix you're problem.
Aaron
Old Dec 4, 2008 | 02:21 PM
89f150's Avatar
Ok that's what I thought it was thank you guys what would happen if I ran the stock turbo
Old Dec 4, 2008 | 02:23 PM
89f150's Avatar
O ya and how much should I advance my timing
Old Dec 4, 2008 | 04:05 PM
peobryant's Avatar
If you run the stock turbo, and don't watch your gauges then you'll start melting things pretty fast. And probably blow the turbo up in the process...
Old Dec 4, 2008 | 04:12 PM
archer39's Avatar
it won't matter how far you advance your timing without a good fuel supply to the injection pump. without case pressure your timing will be retarded.
but once you get a good fuel supply with those injectors you should be able to push the pump to the head. you will know if it's to much.
Old Dec 4, 2008 | 05:03 PM
Once you do your fuel system, archer is right pretty much advance your timing to the head with those injectors.
HorseHauler
13
Mar 12, 2006 11:48 AM
WSUcougars
Dec 14, 2003 08:52 PM
hellotbone
18
Jun 25, 2003 01:16 PM
dieselcrazy
Feb 15, 2003 06:44 AM
soundbrz
Nov 19, 2002 11:36 PM
