Quick question
Old Dec 7, 2006 | 04:25 PM
whereswaldo250's Avatar
Quick question
My low fuel light came on today driving home from school how many gallons do I have left ater the low fuel light comes on?
Old Dec 7, 2006 | 04:34 PM
NukleusX's Avatar
Muted User
From my own experience, I could only say that it is about 1/5 or 1/6 or so of your total fuel tank capacity is left. I could be wrong. See what others have to say.
Old Dec 7, 2006 | 05:13 PM
G1625S's Avatar
I've heard 5-6 gallons when it comes on AND stays on...but have no evidence to back it up
Old Dec 7, 2006 | 06:21 PM
bobva's Avatar
When my light comes on I might be able to sqezzzzz 17 gallons in a30 gallon tank.My S 10 chevy might go 10 miles when light comes on
Old Dec 7, 2006 | 07:19 PM
rlyons's Avatar
When mine comes on steady I have 9 gallons left.
Old Dec 7, 2006 | 07:40 PM
tomd's Avatar
wow... thats interesting. Lets just say that there is 9 gallons for everybody when the light goes on.
9 X 15 = 135 miles.
9 X 20 = 180 miles.
Thats allot of miles left on a tank pegged on empty.
I didnt need to hear this!
Old Dec 7, 2006 | 07:44 PM
Thanks guys for the quick responses. At least I know I can make it to school, there is a diesel station next to school but had no money today as usual I will pick some up tomorrow. YAY
Old Dec 7, 2006 | 07:54 PM
tomd's Avatar
To Play it safe consider only having 3 gallons
35 miles!
Old Dec 7, 2006 | 07:59 PM
Geico266's Avatar
Running on empty is not good for a diesel engine. Sloshing fuel picks up more air, and condensation can add water to the fuel system. Nothing good can be gained by running empty.
Filler up boys & girls.
G1625S's Avatar
I think the wide safety margin was set because the average consumer would likely not be able to bleed the system without getting a tow, unlike most fuel-injected vehicles from the same era that would self bleed on a coulple key-on, key-off cycles.
edit: plus what Geico said. These fuel systems are NOT cheap and do NOT tolerate filth like a gasser will.
Old Dec 7, 2006 | 08:23 PM
The only time my low fuel light came on I got 29 gallons in the tank. I never want to see that light again.
Old Dec 7, 2006 | 08:28 PM
G1625S's Avatar
Always the exception to the rule, Dave first you break a 400hp clutch with 381hp and now this
Old Dec 7, 2006 | 08:33 PM
loch's Avatar
Not to mention fuel cools and lubes the pump, no fuel = no lube, not good. I ran out gas one time and contrary to mosts experiance it started on third try, i tried for 15 or so seconds and sat for a minute, and third it poped right off. But it wont ever happen again if i can stop it.
Old Dec 7, 2006 | 08:36 PM
G1625S's Avatar
A VE-pumped 6bt is extremely bleed-friendly. Took me 4 times as long to bleed a 3 cylinder Yanmar diesel in a John Deere that ran dry than it did to fire my truck with a fresh IP and dry high pressure lines...
Old Dec 7, 2006 | 09:14 PM
Well I think that I will be ok, the station is about 7 miles away and the low fuel light came on and off to day so I probably have have a little more but I am going to fill up before I go to class. Wow I am impressed with the number of replies.
