quick question about down loaders
Old Jun 21, 2007 | 10:33 PM
eodshawn's Avatar
Ok I have a triple dog down loader. the main reason i bought it wasnt really for the power but for the tire adjustment, light changes, beeps and stuff like that. The problem is it doesnt change the speedo for larger tires. So the question is which one does this? and can i keep the bullydog on it and use one of the other downloaders to adjust the speedo?
Old Jun 21, 2007 | 10:35 PM
rustyshakelford's Avatar
smarty to the rescue again
brett
AggieJustin's Avatar
You can't run two downloaders at the same time. If you try, you'll probably end up locking one of them out because the second box will overwrite the programming from the first.
I'm pretty sure that the Smarty does tire size. But if you're looking at getting a Smarty, you might as well sell the Bully Dog. Or just take it to the dealer and have the tire size adjusted if the Bully Dog does everything else you want.
Old Jun 21, 2007 | 10:57 PM
06CTDforAU's Avatar
From what I have heard the dealer can't change the tire size on an 06-07 model. At least that is what I was told. Knowing my dealership though, it was probably a lie.
The only programmers I know of that can change the tire size is the Smarty and the Diablo Predator.
If you like the Bully Dog Triple Dog for it's features just go to your local Bully Dog dealer and see if they have the tire size calibrater (spelling?) that BD is coming out with. That WILL program your correct tire size IF they have it.
Just another option for you if you don't want to switch downloaders....
Old Jun 21, 2007 | 10:59 PM
dodgezilla04's Avatar
smarty adjusts tire size through the abs menu
Old Jun 22, 2007 | 10:17 AM
Armapoc's Avatar
Bully Dog is releasing the Tire Size on the next upgrade. They are also adding Speed Limiter Adjustment to the program. I would just hold on to it for a bit, then run the internet upgrade.
Old Jun 22, 2007 | 11:33 AM
eodshawn's Avatar
Cool thanks for the info!
kingofdodge7131
Mar 3, 2013 10:59 PM
BearKiller
Nov 1, 2006 01:36 PM
BowtiedCTD
Sep 28, 2006 01:08 AM
lglamb
Jun 25, 2006 11:42 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
