Quick gauge wiring question
Go to your fuse pannel with a test lite and the headlight sw. on and hold onto the dimmer and rotate it while you probe the fuses when you find a fuse that the test lite dims than go to the back side of the pannel and try to find the wire going to that fuse and use a scotch lock [ one of those dingeys that let you tap into a wire] do that , and there ya go .
Well,I got power to em'.But the Di-Pricol pyro is not near as bright as the other two are.It says it has LED illumination but I can't get it to work.So I just hooked up the normal bulb and its not enough.Any ideas on why the LED's not working?
BLACK is POSITIVE +
WHITE is NEGATIVE -
I made the same mistake on mine... They put a small label with this on the end of the wires on mine but... I was such a hurry to hook up I forgot about it... OPPS!
Originally posted by darrenG
sure, why not fly in the face of convention!?
No... I was wasn't trying to do that... Oh Well...
I don't know why Dipricol took up the house wiring color scheme...
BLACK is HOT (Positive +)
WHITE is Neutral (Negative -)
aggieengnr
06-09-2009 05:03 PM
HorseHauler
13
03-12-2006 11:48 AM
