Quick boost question ??
Old May 3, 2006 | 09:06 PM
berok's Avatar
I just installed my boost gauge tonight and started er up... I didn't get a boost reading until I got up around 1500 RPM, is that normal or should I get a boost reading of some kind all the time? Other than that I drove around and got on it a little and got the boost up to around 26. Is this good for what I got? maybe dumb question but thanx in advance!!!
Old May 3, 2006 | 09:25 PM
natlchamp2k4's Avatar
Boost is a representation of work or stress put on the motor. The motor is not stressing at 1500rpms, but when you are in the higher gears and driving it hard boost will rise fast because the motor is having to work alot harder. So to answer you question, yes it is normal.
Jamie
Old May 3, 2006 | 10:42 PM
Ph4tty's Avatar
Sounds normal. Some tricked out twins might make boost at idle, but the rest of us have to wait until 1500 rpms or so.
Old May 4, 2006 | 07:56 AM
RowJ's Avatar
Like Jamie said...perfectly normal!
Not a "dumb question". While the turbo is spinning all the time... even at idle....it takes more than idle exhaust gas to spin the turbo fast enough to register boost pressure on the gauge.
At hwy cruise (70-75 mph) with your auto, I would say boost should be 8-10 psi, if I remember correctly. If so, everything is as it should be and the gauge is working correctly!
RJ
Aosipower
Sep 29, 2007 01:54 PM
cquestad
0
Jun 1, 2007 01:24 PM
HorseHauler
13
Mar 12, 2006 11:48 AM
Ramdriver15
Mar 9, 2006 05:54 PM
callum
Sep 26, 2004 06:34 PM
