Question for the transmission Experts
Old 11-22-2009, 08:27 PM
5.9x2's Avatar
My 04.5 had been in a roll over accident when I purchased it and when I got it to the shop and running the truck would hardly move on its own seemed like the trans was slipping (yes i filled it with fluid first) so I put it in low range and drove it in to the shop. Now I have the truck almost done and have excepted that I will have to have the trans rebuilt. However I am wondering if it could be something simple, the truck has 61,000, and although I had to put several quarts of ATF into it, it didn't smell burnt but was dirty. If one of the solenoids were plugged or had a wire off could it make the trans start in a higher gear or have a loss of line pressure enough to cause the problem.
Any thoughts or ideas would be appreciated, I have pulled it in and out of the shop and loaded/unloaded on a trailer a few times and it does ok in low range but haven't seen if it will up shift yet
Thanks in advance
Joe
Old 11-22-2009, 09:00 PM
Raspy's Avatar
Maybe you are just not waiting long enough for the converter to fill back up after sitting.
They can have a drain down problem and they slip terribly after sitting for a few days.
Put it in gear and let it idle for 30 seconds or so and see if it pulls like it should.
Old 05-31-2010, 05:56 PM
mexborder's Avatar
I had 97 dodge tranny serviced and after getting home I noticed fluid pouring from pan--I tighten but most of fluid escaped anyway in 20 miles--what can I expect--damage,no damage, shoot the tech bastard?
Thanks folks
geb
Grodyman
09-07-2011 08:17 PM
dieselJon
09-08-2009 08:04 PM
DodgeDemon
06-30-2007 01:44 PM
Jack Thorpe
08-07-2003 12:36 PM
Dodgezilla
04-01-2003 11:14 AM
Quick Reply: Question for the transmission Experts
