question for those with VA C3.2 stacked w/ EZ
For those with the stack....
Did you use the EZ boost elbow? Did you try it with and without?
And finally...what where your boost numbers in each situation...with C3.2, with C3.2 and Edge, and either with and without elbow?
Thanks!
Thanks!
i didnt opt for the boost elbow... without the v.a. i saw 39 lbs MAX..i have seen 44 with the v.a. on stage 2...., i havent tried the v.a. by itself, so i couldnt accurately say what the differences are... i do know that it is a good stack.... stage 2 egt's are through the roof... my eze is on level 4 all the time, with the v.a. on 1 i hit 1200 when i see 70 mph from a still start---
HUGE egt's
HUGE egt's
Murf
Aug 17, 2007 04:36 PM
rshelton88
Mar 20, 2003 07:14 PM
