question about position of fuel plate
Old 05-03-2004, 03:08 PM
halerazor's Avatar
ok i know that if you take out the fuel plate or get a smaller grind you will get more fuel, but how does sliding it foward give you more fuel. wouldn't the arm that follows the plate not go as far. it would be like having a bigger grind wouldn't it.
Old 05-03-2004, 04:35 PM
DZLPWR's Avatar
Your acually sliding the plate away from the arm that follows the plate, thus causing the arm to go deeper, thus getting more fuel. Away from the arm=sliding plate towards front of truck.
Old 05-03-2004, 09:45 PM
halerazor's Avatar
i thought the contour of the plate faced the front of the truck. so what do they grind to get the power? the smooth side!!
Old 05-03-2004, 10:01 PM
halerazor's Avatar
is it possible to put it in backwards with the tst template, if so i could swear i had mine in backwards would it take away from my power
Old 05-04-2004, 05:11 AM
DZLPWR's Avatar
Im not too sure if the afc housing would go back on if it was backwards. But, yes the profiled part of the plate points to the rear of the truck.
Old 05-04-2004, 09:55 AM
signature600's Avatar
The plate will go in backwards, I've done this!!
BUT, THE AFC HOUSING WILL NOT GO ON !!
Took me about a half hour to realize, with this boards help, that I had the plate in backwards. I was sure that I had it in right, but I screwed up.
Hope this Helps,
Chris
rocktoy
11-29-2010 11:26 AM
Kenny Rhea
10-24-2009 12:12 PM
Cougsfan
10-23-2007 11:17 AM
bob95065
21
08-21-2007 05:16 PM
Txwelder
16
12-13-2006 07:10 PM
Quick Reply: question about position of fuel plate
