question about isspro thermocouple
I'm trying to install my guages and I think I have the wrong thermocouple from Isspro. It is their number R650 and it has a 1/4 inch threaded nut on it. I though they were supposed to be 1/8 and mine is about 2 inches long from the bottom of the threads to the tip..am I missing something or did they spec me the wrong part. I forgot the 7 P's and didn't look ahead to make sure before I drilled the hole. I drilled and tapped for a 1/8 NPT (pre turbo) I guess I can plug it with a brass pipe plug until I figure out what is wrong or until I can get the right one in. Does anyone know the right part number? ??? T.I.A.
Administrator / Scooter Bum
Re:question about isspro thermocouple
Mine looked like this
and is adjustable for length by loosening the ferrule and sliding the thermo. up or down.
[quote author=Dr. Evil link=board=7;threadid=23403;start=0#msg219762 date=1070840536]
Which p/n is that???
[/quote]
R658 THERMOCOUPLE ADJUSTABLE
www.isspro.com
[/quote]
www.isspro.com
yep, looks like mine is the wrong part number. It's not adjustable but looks like yours Shovelhead. Is yours 1/8 or 1/4?
I got mine at eguages.com because Rod was out of them and didn't know when he would have a couple of the three guages I wanted in. I dont even see that part number on eguages site so guess Ill need to call them and set up an exchange..
thanks for the info. I cant see doing a 1/4 inch hole in the manifold so I can't adapt this one to fit..
thanks folks
thanks folks
thanks folks, I either need the 658 or the 658s not sure which but I have the 1/4 now and want the one I can use with a 1/8 npt hole.
I think so...Ive seen guys drill and tap 1/4" NPT then use a 1/4"X1/8" bushing to install the thermocouple probe.....I dont see a problem as long as you use some high temperature antiseize on the threads....
scjfly
05-19-2011 12:53 AM
