Question about clearance lights
Old 02-29-2004, 10:32 PM
jrs_dodge_diesel's Avatar
Question Question about clearance lights
Howdy y'all,
I have a question about the rooftop clearance lights. My truck currently has no clearance lights. I really like the look of them, and would love to have them on my truck. Is his something the dealer could install, or does anybody make kits to install a set? Any information would be appreciated.
Old 02-29-2004, 10:37 PM
Lil Dog's Avatar
You can either have the dealer install the factory lite set or you can order the lite kits from DC. They have two kits available one with the older style lights and ones with the 2000 and up style. I ordered a kit for my last truck with the old style and ordering again for this truck.
The kit comes with the lites, screws, wiring and instructions for hooking up the lites. Also the instruction sheet is a template for drilling the holes for the screws and wires. The complete kit ran me about $80 Cdn and was just as cheap or cheaper than aftermarket sets that don't look as nice.
J-eh
Old 02-29-2004, 10:43 PM
quantrill88's Avatar
has anyone had the dealer install them? if so, do they warrantee the work and how much did they charge
i personally dont feel comfortable drilling holes in my roof and would rather have a dealer do it if theyll warrantee it.
thanks
Jeff
Old 02-29-2004, 11:02 PM
thanks
Jeff
My thoughts exactly. As good as I am with tools I really don't want to screw up my truck. The price sounds real good for the kit though. I don't know how much $80 CDN is in dollars. Maybe around 60 bucks? Thanks for the quick replies.
Old 02-29-2004, 11:04 PM
actually, the mopar kit ive seen here is only 79 bucks, go figure
Old 03-02-2004, 09:02 PM
6cylinders's Avatar
How do you hook up the wires? Is there any wiring already there?
Please explain the electrical /wiring install. Thanks
Old 03-02-2004, 11:41 PM
Lil Dog's Avatar
The wiring with the kit comes with the setup to go to each light as well as the runner for down the a-pillar to the under dash junction. There is a connector just below the clutch bracket where all the wires come and go. There is a pin in there that you connect to for the lights as far as I can remember. The instructions tell you where to plug in.
Old 03-03-2004, 12:45 AM
BigBlue's Avatar
Get the cab clearance lights installed. My girlfriend bought them for me for christmas from dodge and the whole kit (wiring, bulbs, housing, template, and instructions) was ~$80. It plugs into the back of the inside fuse box and comes on with your parking lights and is also fused now. I didn't have to replace the fuse either (directions didn't say to either). I payed someone to drill the holes and line them up and they charged ~$75 to do that. The dealership wouldn't even do the install and if they did, they wanted to charge for 3 hours of work at $80 an hour. The guy that did mine did it in about an hour. He specializes in rebuilding old cars so body work was easy for him. After about 2 months of use, I have no leaks and they look great. Now, I just need to buy the 01 lenses for them. Girlfriend got me the 96 lenses and they stick up more than the 01 lenses do.
Old 03-03-2004, 11:43 AM
Does anyone have the part number for this kit? My dealer couldn't find anything for me. I was the first person to ever ask for the lights.
Old 03-03-2004, 12:20 PM
Lil Dog's Avatar
The light kit for the older pre 01 lites
Mopar # 82205120
I think the mounting for the 01 lenses require a larger hole in the center of the light mount to allow for the bulb to be recessed into the cab. I would check this out before ordering the lenses.
And thanks for the update on the plug in. I was getting confused with another plug for brake controller .
J-eh
Old 03-03-2004, 01:48 PM
BigBlue's Avatar
If that's all that's required to mount the 01 lights on the truck, I might go and pick them up today. A dremel makes a nice hole.
Old 03-03-2004, 03:15 PM
Mopar # 82205120
J-eh
Cool, thanks for the number. Do you by chance have the one for the 01 and up lights?
Old 03-03-2004, 10:41 PM
Lil Dog's Avatar
Sorry I do not, but once you find that light kit they should be on the right track for that set as well.
Old 03-04-2004, 10:54 PM
DTR's Cow Boss
DodgeCowboy's Avatar
i just had the 01 and up cab lights installed on my 96 when i get my recipe i will see if i cant find the part number
bortzy93
08-31-2010 08:18 AM
afoulk
0
10-06-2007 12:16 PM
Ramcam
04-07-2007 03:43 PM
Mcmopar
71
02-27-2007 01:58 PM
cummins dsl
22
06-27-2005 11:53 AM
Quick Reply: Question about clearance lights
