Quadzilla RAIL GAUGE erratic LP readings....
Old 08-13-2009, 03:31 PM
sallyman1's Avatar
I have a quad rail gauge. i only use it for lift pump pressure as it fries rail sensors so i dont even wanna go thjere. anyways i get 16-18 psi steady on the highway or when im into the fuel pedal a lil bit. (i have FASS system 95/150gph) but when i putz around my small town and goto stores etc..i get readings of 0-10 psi very very fast and erratic. what is this? my fuel tank is full and my fass is new and installed right....??/
Old 08-13-2009, 03:38 PM
trailinone's Avatar
Mine was eratic until I put the Airdog on. Now it stays at 17-19 until I get to 1/4 tank, then it warns me real quick to find a pump.
Chris
Old 08-13-2009, 04:11 PM
sallyman1's Avatar
mine isnt a 1/4 tank issue. it does this when full
Old 08-16-2009, 05:19 PM
D45
D45's Avatar
Do you have the new or the old Quad RPG?
Old 08-16-2009, 10:47 PM
Fisherguy's Avatar
Sounds like your FASS is still screwed up.
A RP gauge will not fry your rail sensors.
Old 08-17-2009, 11:09 PM
agregersen's Avatar
its the quad fp sender, send it in they have an updated one,mine did the same thing. you could put a mechanical gauge on and verify it if you want.
xxwildbillxx
06-15-2008 04:59 PM
90canuck
10-11-2007 03:33 PM
firehawk
07-04-2007 02:43 PM
muddybeast
11-09-2006 07:29 PM
herb
09-04-2005 10:24 AM
Quick Reply: Quadzilla RAIL GAUGE erratic LP readings....
