quadzilla boost fooler
need some help/advice. i have a BDTDPP stacked with a diablo PP on my truck. would it be safe to install the boost fooler (DTR store has it) with what i have already? will i see some increase in performance as well? any issue's?
thanks in advance!
thanks in advance!
well, ordered it earlier from DTR. i'm sure it will come with instructions but i would like to know up front...where will it plug in at? and if there is something else that is plugged in already, should the boost fooler plug in first or can it be piggy backed on whatever is there already?
thanks again for the help and education
got the boost fooler today and installed it. took it out for a spin and the boost doesn't drop off like it used to when the tranny would shift to a higher gear. it continue's to climb up to around 40psi and then i need to get off the excellerator. good lord! this thing is awesome.
General rule is to plug the boost fooler into the sensor last in line before the ECM that way other fueling boxes will read the true boost.
Won't hurt to change it either, the results will be the same.
Killdmycobra
11-12-2010 05:15 PM
dodgediesel
10-16-2009 11:28 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
dieselpower04
09-25-2006 03:22 PM
CDoskocil9
09-21-2006 09:26 PM
