Quadzilla Boost Fooler + overnight = P2509
Old 04-11-2007, 08:41 AM
HOV
HOV's Avatar
Installed the Boost Fooler on Monday evening. Tuesday afternoon after my second startup I get the P2509. (ECM intermittent signal)
Checked the connections and they seem tight. Connectors are fully engaged. Battery terminals look fine.
Is it a coincidence? Or has anyone else received a P2509 for the Quad boost fooler?
Old 04-11-2007, 08:44 AM
Totallyrad's Avatar
I've ran 2 and never a code.
Old 04-11-2007, 09:23 AM
973604x4's Avatar
i have run 3 different quad boost foolers....no codes
coincidence. PM Quad about it....but im sure he will chime in here anyway.
Old 04-11-2007, 09:29 AM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Did you use Dialectric grease on all the connections?
Sounds like a connection not being as tight as you may think it is.
Old 04-11-2007, 10:18 AM
HOV
HOV's Avatar
Dielectric grease was needed on the MAP sensor connections?
Old 04-11-2007, 10:21 AM
E-Train's Avatar
Do I need this
Do I need one of these if I'm going to just run the SMARTY?
Admin Team Leader
It may not be your problem, but I have seen hundreds of issues solved with a little dab of that stuff
Old 04-11-2007, 10:32 AM
HOV
HOV's Avatar
Well, it's a good idea and can't hurt to try a little. I'll reset my ECU at the same time and see if it pops up again.
I've put together plenty of electrical connectors in my time; this is defintely not a loose one. I was impressed with the quality of the product and it went on easy with a secure connection.
Old 04-11-2007, 11:40 AM
973604x4's Avatar
Depends on which Smarty tune you download. I would suggest it.
Old 04-11-2007, 03:05 PM
qzilla's Avatar
P2509 - Powerdown Data Loss Error
Possible Causes:
Poor Connections at the batteries
Low Battery Voltage
Open Fused B+ to ECM
Open Ground Circuit
Battery + shorted to other circuits
Return circuit shorted
Battery + Shorted to ground
Intermitten condition
Sounds like maybe something battery related? I cannot imagine any possible way that a boost fooler could cause this?
Old 04-12-2007, 09:59 AM
HOV
HOV's Avatar
Possible Causes:
Low Battery Voltage
Open Ground Circuit
I thought maybe the data loss could be a weak or intermittent MAP signal stemming from me not putting the connectors on tight enough.
But the connectors are on pretty tight! I'll re-seat my battery cables, resetting the ECM in the process and see if it comes up again.
Old 04-16-2007, 07:34 AM
HOV
HOV's Avatar
Well, it looks like it really was a coincidence. When I started up my truck to move it to the driveway to reset the ECU, the CEL cleared itself and never came back.
Thanks for all the feedback
Old 04-16-2007, 08:21 AM
Dodgezilla's Avatar
So, have you noticed a difference in the truck with the fooler on?
Old 04-16-2007, 10:18 AM
HOV
HOV's Avatar
Well, I really hate to judge things by butt-dyno but yes it does feel like there's more giddyup at WOT. At least that's what I'm telling myself.
Next mod: muffler delete and that's it.
Old 04-16-2007, 11:10 AM
Dodgezilla's Avatar
I'm thinking about DeBombing mine right now. This truck is just too touchy when it comes to mods. My muffler delete will stay there though. I love the way it sounds.....
Killdmycobra
11-12-2010 05:15 PM
dodgediesel
10-16-2009 11:28 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
dieselpower04
09-25-2006 03:22 PM
CDoskocil9
09-21-2006 09:26 PM
Quick Reply: Quadzilla Boost Fooler + overnight = P2509
