Quadzilla Adrenaline shutting off!!!
Old 04-06-2009, 11:10 PM
stroker4501's Avatar
My truck will run good for about 10 minutes and then i have to turn the key off and on for it have anything above level 2 pump wire tapped good. box seems to shut off or something... anything that would help would be great....
Old 04-06-2009, 11:15 PM
nate_88's Avatar
A lot of people are having the same problem, including me. I've been working with Jeremy for a while now and they've been trying to work out the problem. Justin called me today to give me an update because Jeremy had to go out of the office, but I'm going to talk to Jeremy or Quad tomorrow to get another update from the main guys. I'll let you know what I hear.
Old 04-06-2009, 11:37 PM
sounds good man i hope something will get figured out soon..... running half power would make me really ****** at the dyno next weekend.....I think it just started happening with these new tunes...
Old 04-07-2009, 12:00 AM
nate_88's Avatar
I've found that if you start running the truck on PL 2 or below once you start the truck you can control when it kicks out, at least on my truck. I'll run around on PL 2 until I want to use something above that (like if I'm passing someone, and almost always 10), then drop it back down to 2 when I'm done. If they don't come up with a fix by then and you're driving your truck to the dyno then try that and see how it goes. Drive it there on 2 then kick it up to 10 when you're on the dyno. Actually, try driving it like that this week and see if that works. If all else fails, reset the Adrenaline when you get on the dyno and the power should be there. Hope this helps.
Old 04-07-2009, 07:51 PM
nate_88's Avatar
I just got off the phone with Jeremy and it sounds like they're having one of their local guys coming in tomorrow that's having the same problem as us. He said that it looks like it's the pump stretch that they're having problems with because it keeps losing signal of some sort. They're going to work on the guy's truck tomorrow and he's going to give me a call tomorrow after they're done and give me an update. Hopefully it gets fixed!
Old 04-07-2009, 11:54 PM
yea i called today too. talked to Jeremy supposed to be fixed by the end of the week I'm hoping its fixed soon i tried different tunes today still the same thing....ill be waiting patiently...
Old 04-08-2009, 05:38 AM
gwhammy's Avatar
I've been having the adr. loose it's tune which I believe is is what you guys are talking about. They called me the other day and had me send my pulse in. They were thinking it was causing the problems. You could unhook the adr. for a few minutes and it would work fine when you hooked it back up. I hope they figure it out, it's getting annoying.
Old 04-08-2009, 07:45 PM
any word???
Old 04-08-2009, 08:26 PM
nate_88's Avatar
I haven't heard back. Jeremy said he'd call or email me but he probably just got really busy. I'll give him a call tomorrow and get an update.
Old 04-08-2009, 09:45 PM
sounds good i just lost to a hemi because it shot off when i was spooling up.....starting to get impatient
Old 04-08-2009, 10:59 PM
nate_88's Avatar
It shut off DURING spool up? Are you sure you didn't lose it before you started to take off? If I begin to go into the throttle with it working, it will always work, but sometimes it will kick out after I'm out of the throttle. Luckily mine was working the other day while I was racing 3 girls in a Civic on I90!
Old 04-09-2009, 10:38 AM
STACKED's Avatar
yeah i was supposed to go up there yesterday but i got too busy i am going to go today i will let y'all know how it goes.
Old 04-09-2009, 10:46 AM
Crazydave's Avatar
I too have been fighting this problem of losing the wire tap. It started after the firmware update. Hopefully it gets solved soon
Old 04-09-2009, 01:45 PM
nate_88's Avatar
Are you the local guy that they've been having come in?
Old 04-09-2009, 02:51 PM
i don't know when it shut off but when i spooled i had nothing STACKED get in there man i need to get this figured out soon!!! Dyno event is coming up
Quick Reply: Quadzilla Adrenaline shutting off!!!
