Quad XZT+
Old 02-21-2008, 08:34 AM
GreatTruck2001's Avatar
Quad XZT+
Just installed the Quad XZT+ yesterday -- the install went as easily as advertised! (That's saying something for a clutz like me!) Anyway, I have two questions.
1. Can someone tell me which switch position is which setting. I believe having the switch over the black wire is fuel + timing but am uncertain about the other 2 positions
2. Are the new units (ordered 2/15) shipped with the most aggressive settings (XZT+ 2000)?
Thanks again! This site is a life-saver!
Old 02-21-2008, 10:01 AM
hamilton71801's Avatar
Can't reply about what's shipped with it now but you can put whatever you want to from the web. Now back to the positions. In my case, up is off (high idle), middle is timing only and down is time/fuel. If you install the swtich upside down, then it will be time/fuel, timing, off.
Old 02-21-2008, 11:25 AM
Dinner's Avatar
The off position is when the switch is flicked up (or down) towards the little square shape spot on the washer behind the switch.
Here is a pic if it helps. In my case my Off position (high idle) is when I flip the switch up. Right now it is in the middle (timing only) and then down is timing and fuel.
Old 02-21-2008, 01:20 PM
kwast's Avatar
Only thing to remember is the timing only setting is in the middle!!!!!!!!
so off is the opposite side of the fuel/timing side.......
sCreamin400
11-02-2008 01:46 PM
codythom
11-03-2005 05:44 PM
robert chilton
27
11-03-2005 12:23 PM
donhov
08-01-2005 07:59 PM
Quick Reply: Quad XZT+
