quad xzt installed
Old 08-23-2007, 06:04 PM
dku7's Avatar
quad xzt installed
Finally decided on a chip and I'm really happy with the xzt. Since putting the xzt on I haven't noticed any change in the engine noise except maybe a bit when accelerating hard but that's normal for a chip with extra timing I think.
This chip seems to make my truck run like it should of from factory. The power is very smooth and the tranny shifts are way smoother and quicker than before. Not sure why but the driveability as a whole has improved 100%. For guys wondering about the power increase with only 65 horse it makes a big difference - tire spin from 3/4 throttle take offs
I bought it more for towing and I can't wait to see how much it helps but with the truck empty I am very happy with it. I'm hoping for a mileage gain too but I haven't had it long enough yet to know but I won't be surprised to see an increase as I don't have to use nearly as much throttle to accelerate now. And I don't have to worry as much about my tranny since I don't have a switch or program to "turn it way up" and wreck stuff. It would be way too tempting for me
btw my truck is an 04 auto 305 hp.
Old 08-23-2007, 07:26 PM
DTR 1st Sergeant
soulezoo's Avatar
Hey good for you! Now the bombing bug will bite you-- careful!
Fill out your sig so when the questions arise, you can get a good answer!
Enjoy the toy!
Old 08-23-2007, 09:42 PM
gtstrkd's Avatar
I installed one a week ago great product gained a solid 1mpg
Old 08-24-2007, 07:30 AM
bluebull's Avatar
Without gauges I would be careful towing. I just installed an XZT on a 06 truck and mashing the throttle will bring those EGT's right up to where you would want to back out of the throttle. This was without a load, with a load the EGT's would climb faster and higher.
Old 08-24-2007, 07:56 AM
iweb's Avatar
Yep get the Commander or other gauges, I can get 1450 egt's realy easy with my XZT so you need to keep a watch.
Old 08-24-2007, 11:49 AM
paroxysym's Avatar
i thought it was adjustable... but after getting off the phone with quadzilla its only adjustable if you add the commander. running a switch wont change the power levels, just change the color of the led... ****.
Old 08-24-2007, 01:55 PM
dku7's Avatar
No it's not adjustable but it makes the truck run so much better at 65 hp without being too much for the tranny so a switch would be a waste since it would probably never get turned off.
metalbasher
09-17-2007 08:49 PM
t-boe
09-10-2007 07:25 AM
Mark Hodowanec
07-30-2007 08:33 PM
RedRacer44
05-03-2007 10:37 AM
WEATHERBY460
09-04-2006 08:14 AM
Quick Reply: quad xzt installed
