Quad STD. Stacked with EZ
Old 01-09-2007, 11:17 AM
Bone's Avatar
Has anyone stacked a Quad std. and the Edge EZ?? Would this be to much pressure? would they stack well?? I have run the EZ for a couple years, and just got a Quad std. I went away from the EZ due to pressure only and hearing that pressure over a period of time was bad on injectors. But I knid of like the feel of the EZ over the Quad box. But like the quad for its timing and duration. I have an 04 auto, stock other than the box.
Old 01-09-2007, 01:48 PM
MikeyB's Avatar
The problem is the Quad standard adjustable box also does some pressure. Question is how much with both. Best guess is to get a rail pressure gauge and monitor with both boxes on (if you decide to stack).
Personally I wouldn't do it.
MikeyB
Old 01-09-2007, 02:35 PM
973604x4's Avatar
MikeyB
couldn't have said it better!
Old 01-09-2007, 03:48 PM
NB64's Avatar
Some have said that the EZ uses pretty high pressure (Not over the max but close) The quad also uses some presure. I would probably use one or the other and find a timing only type module.
Old 01-09-2007, 04:21 PM
Bone's Avatar
Thanks for all the replies. Kind of what I thought but I thought I would ask, there is alot of knowledge on this sight....may as well use it. I've been a lurker(?) for a while, and just joined a while ago. If you don't mind another question how do you add what year your truck is and the mods ect.??
Old 01-09-2007, 04:28 PM
acook's Avatar
Go to the top of the page and click on user CP and then on the left (i think) theirs a section for signiture
Old 01-09-2007, 05:10 PM
KelschKid's Avatar
I tried this stack for a week or two right when the quad came out and it sounded like a barrel full of monkeys with hammers rolling down the hill but it ran like a raped ape I wouldn't ever try it again and I'm pretty sure that I cracked an injector or something, but thats why hindsight is 20/20 (it also smoked like a train )
Old 01-09-2007, 05:16 PM
BigDave12768's Avatar
I don't think the Edge EZ does pressure. I thought it was a Duration and timimg type box and the quad was more of a Pressure/ timing boost fool box
wap
wap's Avatar
I have heard peopel say that they have reached pressures as high as 29k with the quad alone, no way I would stack 2 pressure boxes even if neither one goes over the facotry limit, thats just askin for trouble.
Old 01-10-2007, 04:25 AM
Dodgezilla's Avatar
The EZ is a pressure only box. I wouldn't do it either.....
ptgarcia
03-06-2007 09:09 PM
koogala
05-10-2006 10:44 PM
Syndicate
04-03-2006 06:31 PM
Spooler
03-17-2006 06:02 PM
Steve034x4
06-07-2005 05:14 PM
Quick Reply: Quad STD. Stacked with EZ
