Quad race module??
Old 01-29-2008, 06:21 PM
Billm2004's Avatar
Question Quad race module??
How do you guys like the quad race module? Would i benefit from it more than the mp-8 with my BDTD? Or how about all 3? I dont really know too much about timing, pressures, durations. Could i have all three or am i better off how i am? Im looking for the most HP possible. I dont tow heavy or anything, Im just try to get the best possible time when i race on the weekends. Hopefully i will have a set of injectors soon too if it makes a difference in the answer.
Thanks for the advise!
Old 01-29-2008, 10:31 PM
Billm2004's Avatar
Anyone? quad?
Old 01-29-2008, 11:59 PM
qzilla's Avatar
Well you cannot use all 3.
I am not 100% confident that it would be better enough to warrant swapping out the MP8 for what you are doing. I am confident to say that it won't be worse but, there are just so many combos possible there is no way to test them.
Here are the advantages, take them for what they are and if that means it would be worth it to you then make a swap.
Customers say our boxes have the best bottom end
You get a built in Rail Pressure gauge (as well as coolant and boost) but the RPG is the big one there
It has built in USB which means you can try some different things to see what works best on your truck and in your conditions. These are free and you can swap them out all you want.
You can sell your boost fooler
The Control Pod gives you a definite setting so that when you find the perfect setup you can go back to it for sure. With the resistor **** unless you are all the way off or all the way on you will have a hard time getting the exact same spot.
Old 01-30-2008, 12:32 AM
Billm2004's Avatar
Thanks for the points
05CTDN8
27
08-30-2007 11:36 AM
buickturbot
08-13-2007 10:24 PM
Hoss
01-08-2007 02:34 PM
DWG05
11-26-2006 12:29 PM
carcrz
10-31-2006 04:45 PM
Quick Reply: Quad race module??
