Quad EMI
Old 03-28-2007, 09:52 AM
XLR8R's Avatar
Quad EMI
Hey Quad,
Would shielding the XZT harness from EMI (cross talk) be beneficial?
Anyone else tried this?
Opinions?
Old 03-28-2007, 10:51 AM
MikeyB's Avatar
Only if there's a problem from crosstalk, like with a Ham or CB radio.
MikeyB
Old 03-28-2007, 10:53 AM
dodgezilla04's Avatar
my quad would set a light and lose power when i originally had it mounted to the brake control module under the dash. i moved it as high up the dash that i could and no longer have had any problems.
Old 03-28-2007, 10:57 PM
XLR8R's Avatar
That's what I'm talking about; I'm wiring the rest of the bombs and would rather get the Quad harness installed trouble-free the first time, with the box located where it won't have any issues.
Old 03-29-2007, 07:42 AM
MikeyB's Avatar
Mike,
If you feel like you need it do it. Also make sure to ground the shielding.
MikeyB
Old 03-29-2007, 11:10 AM
XLR8R's Avatar
Thanks Mike - would something low budget like grounded tin foil wrap inside the plastic flex conduit be fine? I really don't want to put the harness inside flex armor conduit! I have some SS and some Cu braided sleeve in the shop, but probably nothing long enough... besides, that stuff is $$$
Old 03-29-2007, 11:11 AM
i just mounted my quad to the panel above your knees, just as high as i could get it, on the right side of the panel is a flat spot about the size of the quad when laid on its side, i just doubleback taped it there, and I can see the led when driving. never an issue after that.
Old 03-29-2007, 12:28 PM
MikeyB's Avatar
Yep, just wrap the wiring with foil and then add the flexible wire loom.
MikeyB
89dieselkong
07-27-2010 10:55 AM
P.J
10-13-2006 01:54 PM
hllbllyhellion
08-19-2006 06:18 AM
JORDAN
10-19-2002 06:17 PM
Quick Reply: Quad EMI
