Quad commander?s
Old 06-13-2007, 11:20 PM
Big T's Avatar
Quad commander?s
Well I got it today and I must be a idiot I am trying to figure out all the wirea and were they hook into. The single strand that goes to the pyro is no problem it is all the other wires that are the problem. I have a lot of ?s. None of the other wires have any markings so not sure where they go. I thought they would just plug in to pigtails but I have to splice some. Not sure wich leads go where. Also how do I put the trans line (1 of the ones I know on the Multiple line set up) in the output line? do I need a special atachment to tap into it. I did not order the boost kit wich I will but what do I do with that line tell I get it?
Old 06-14-2007, 12:43 AM
Luvnacumns's Avatar
Call me tomorrow and I will help you.. S
Shane 208-539-3461!
Old 06-14-2007, 08:56 AM
welndmn's Avatar
Did you not get a copy of the instructions?
Old 06-14-2007, 09:02 AM
qzilla's Avatar
It is actually pretty easy to install. You do not need to splice any wires you just tap onto 2 of them.
The wires are not marked but, they are color coded. The instructions will tell you which color wire goes where.
A few minutes of reading the manual will make it all clear!
Old 06-14-2007, 09:29 AM
tristan21's Avatar
Just wanted to say thanks for havin nice people to talk to at your place. Ive made several calls over there and never bought anything (not directly from you anyway) and have never talked to one person that seemed "tired" of answerin ?'s. I was gonna get a boost fooler but Jeremy instructed me that I probably dont need one with what im runnin. Now Thats Good Service. I will be getting the commander as soon as it controls the tst and has the timer, mp8 control (I gotta keep as many of those switches ***** and boxes outta site as I can), etc. I guess since I want it all I might as well ask it the display is multi-colored or just like the edge/juice?
Anyway I would recommend your stuff to anybody. Im not even a customer and im satisfied. You guys like DonM, Thuren, scotty, pete sbc, bob wagner, all make this site a valuable source of info, just wanted to say thanks.
Old 06-14-2007, 10:40 AM
qzilla's Avatar
I am happy to hear they answer questions without problems, if they ever don't I sure hope someone tells me!
We have the MP8 control out now. We do not have the TST or the turbo timer yet. I will tell you that most likely we will not be able to do the TST and MP8 on the one monitor.
The display is similar to the Attitude but, much larger.
Old 06-14-2007, 10:52 AM
Big T's Avatar
Hey Quad just not sure on a couple hook ups. Wich one to hook to on the Map sensor wire tap. It says connect the supplied wire tap to pin D. So if I am looking at the front of the truck it is near the back to the right of the Valve cover it is the the connecter with 4 wires I want to tap the wire on the right closest to the driver side.
Also can I hook just these up and due the EGT later and plug it in?
The fuel kit if I order it were doese i hook up at?
Old 06-14-2007, 11:05 AM
qzilla's Avatar
http://www.quadzillapower.com/downlo...nder_main2.pdf
Look on Page 14. It shows what the MAP sensor looks like and which wire to tap. IT is the 4 pin connector and has a blue seal. You connect the blue wire to it.
The fuel pressure kit comes with a tapped banjo bolt. You remove a factory banjo bolt on the CP3 and replace it with the tapped bolt. Then you screw the fuel pressure sensor into it. Then you connect a seperate wiring harness to it and run a yellow wire to it.
Old 06-14-2007, 11:13 AM
tristan21's Avatar
The mp-8 **** really isnt that obtrusive I suppose I just see that where I'm goin the least amount of **** and screens the better. Thanks though. And im sure in a couple of months when you get the TST/timer workin that youll put some posts on here and let us know
Old 06-14-2007, 11:19 AM
Big T's Avatar
Page 14 is for a ford?? due I tap to all 4 wires 3,2,1 just not sure I am not that techy sorry.
Old 06-14-2007, 11:36 AM
dodgezilla04's Avatar
page 14 of the pdf when viewed with acrobat is the map, trans, and coolant temp sender.
if it is printed, or you're looking at the numbers on the bottom of the page, its page 11
just read the directions thoroughly several times before starting the install.
Old 06-14-2007, 12:23 PM
qzilla's Avatar
Page 14 on the link I posted above. Shows a great picture!
Old 06-14-2007, 12:38 PM
Big T's Avatar
I think a big light just went on (in my head) the tenth time I read it I think I got it know. I hate when I look stupid but trust me I am use to it. I always have learned better buy watching than reading definetly a hands on person. Thx To all when I get home I will get the instal done. I hope I want have any more ?s but I will not gauranty anything. Pretty bad for a straight A student except for spelling!!!!!!!
stock03
11-09-2006 11:27 PM
BMH95
08-25-2006 11:28 AM
tennman
08-17-2006 09:53 PM
bigboi999
06-21-2006 11:01 AM
B2hibry
06-17-2006 03:56 PM
Quick Reply: Quad commander?s
