quad adrenaline question
Old 08-13-2008, 08:52 PM
kennyblatz's Avatar
my box has been working great for the past few weeks with my new vp on but yesterday it stumbled on PL6 and then PL 2-10 became all same power as 2. i checked the stealth box connection and cleaned it up it worked again but today when i turned it up same thing happened it dropped back on to pl2 power.
could it be anything aside from the wire tap
thanks alot the augest blackout is this weekend i need my truck
Old 08-13-2008, 09:10 PM
Fern's Avatar
Sounds like the wire tap, pull the insulation back and solder the connection and heat shrink the connection. They have been known to vibrate loose.
Old 08-13-2008, 10:08 PM
braxton357's Avatar
What do you mean by "stumbled"?
Old 08-13-2008, 10:27 PM
kennyblatz's Avatar
felt like it was flipping between pl 2-6 if that was possable, checked stealth cover seemed like it may have backed off again. thanks for the replys
Old 08-13-2008, 10:53 PM
J Lent's Avatar
You sure you screwed the allen key in far enough before tightening the locknut?
Old 08-14-2008, 12:50 AM
kennyblatz's Avatar
it had backed out that was the problem thanks
kennyblatz
01-29-2009 10:28 PM
bnold
2509
07-24-2008 10:57 PM
sway825
12-14-2007 07:57 PM
tex23455
11-21-2007 04:38 AM
vzdude
10-17-2007 04:32 PM
Quick Reply: quad adrenaline question
