Pyrometer, boost limits??
Old Jun 25, 2007 | 06:43 PM
Jim Dollinger's Avatar
We use our 2007 Dodge,automatic transmission and 6.7 l diesel for towing our RV. This weekend we had three gauges installed: pyrometer, turbo boost and transmission temperatures.
What range should I expect to see on these gauges under normal towing? What would the maximum readings, for each, I would not want to exceed?
Jim
Old Jun 25, 2007 | 10:42 PM
dodgezilla04's Avatar
Jim, Welcome to DTR
pyro, i assume it is before the turbo. you will not want to exceed 1400*, not exceed 1300* for more than a few minutes. (if pyro is after the turbo, it will read 300* below these numbers, so 1100, and 1000*)
boost should be around 33-34 stock.
Old Jun 26, 2007 | 08:39 AM
Thank you for the information.
Shipskym
Feb 5, 2014 11:27 AM
drew03
Aug 27, 2005 11:03 AM
drtwister
Apr 10, 2005 08:06 AM
Hummin Cummins
24
Feb 24, 2003 10:35 AM
