View Poll Results: Where to place the Pyro Probe?
Pre Turbo
92
89.32%
Post Turbo
10.68%
Voters: 103. You may not vote on this poll
Pyro Probe - Pre or Post Turbo
Old 05-17-2007, 10:27 AM
Rollin' Smoke's Avatar
just want to see what you guys suggest for a upcoming install I will be doing......thanks alot
Old 05-17-2007, 10:37 AM
cbrahs's Avatar
go pre then if you choose to get a box that has a digital pyro gauge then you can go post and monitor both sides.
Old 05-17-2007, 10:39 AM
WUnderwood's Avatar
PRE is the best way to monitor EGTs
Old 05-17-2007, 11:05 AM
Rob C's Avatar
see your other thread for my answer.
Old 05-17-2007, 12:11 PM
CTDinMT's Avatar
PRE is the only way to go...
Old 05-17-2007, 12:14 PM
wmonroe's Avatar
I have mine in pre-turbo.
Will
Old 05-17-2007, 02:39 PM
Pooter's Avatar
Pre is the only way to get an accurate reading.
I want to see the hotest temps my engine is producing.
I have one on top to monitor 1-3(attitude pyro) and one in the "collector" part of the manifold right before the turbo, in the back section, monitoring 4-6...
Old 05-17-2007, 02:43 PM
CD in NM's Avatar
Mines pre-turbo, monitoring 4-6 temps at the collector. Best place to see max temps accurately.
CD
Old 05-17-2007, 08:53 PM
RamWheelsBy4's Avatar
I have two pre-turbo.
Old 05-17-2007, 09:27 PM
RDZ
RDZ's Avatar
On my Dmax its tapped right into my header. Best way to get a reading.
Old 05-17-2007, 09:32 PM
Mexstan's Avatar
Go pre. Unless you do what I did just for fun and have both pre and post. One gauge, selectable between two probes.
Old 05-17-2007, 09:52 PM
nelrod's Avatar
I agree, mine is pre also. However, most road tractors have them post turbo I think.
Old 05-17-2007, 10:19 PM
03 ant a hemi's Avatar
I had written a reply to this vote about pre and post turbo. But it seems to have dissapeared. I guess no matter what the site opinion is pre turbo.
In the future I will use this site as a read only forum. this isnt the first time and wont be the last time this has happened.
Good luck, keep the openess of the forums alive.
Old 05-17-2007, 10:41 PM
Luvnacumns's Avatar
Both!!!!! If your goona run one go pre!!!
Old 05-18-2007, 12:15 AM
SundayMoney's Avatar
So is it really not worth installing one after the turbo?
I'm installing my Pacbrake this weekend and it has a port for a pyro. I was considering installing the pyro at the same time. Maybe I'll rethink it.
Quick Reply: Pyro Probe - Pre or Post Turbo
