pyro-1150
Old 04-07-2006, 01:22 PM
Boosted12's Avatar
pyro-1150
hey, my pyrometer is only reading 1150 for temp, so do you think that i could grind my #100 plate almost down to a #0?
Old 04-07-2006, 02:16 PM
STACKED's Avatar
yeah you need to do something to get those EGTs up.
Old 04-07-2006, 02:17 PM
RustyJC's Avatar
Obviously, you're over-aired!! More fuel!!!!
Seriously, that's assuming your thermocouple is mounted pre-turbo.
Rusty
Old 04-07-2006, 02:57 PM
Willy91's Avatar
You probably could grind it to a zero without hurting anything. You'll just have to watch your EGT's a little closer.
Boosted12's Avatar
ya, its right before the turbo, so a #0 plate should give me a lot more power to, whats the highest EGT i can go?
Old 04-07-2006, 02:59 PM
Boosted12's Avatar
with what i got, how much hp/tq do you think ill be puttin down, i want to get it dynoed in a couple months
Old 04-07-2006, 03:51 PM
Willy91's Avatar
The 0 will give you more power on the bottom end, but will be about the same on the top end. 1250 is the max sustained EGT's you can run, but you can go alot higher than that as long as you do it for very short spans of time.
Old 04-07-2006, 09:45 PM
bama's Avatar
i couldnt imagine how many times i went to 1800 for about 10 second bursts on my 02.......i know it was slowly killing it,but,it never had a hiccup.............bama
Farmall Power
01-17-2010 12:17 PM
hobbyman
42
03-24-2009 12:01 PM
robert78.5
12-02-2008 01:58 AM
djgaston
12-24-2005 03:24 AM
Clay
03-21-2003 10:53 PM
Quick Reply: pyro-1150
