when to put a programmer on
Old 10-17-2006, 11:17 PM
hyunsinsone's Avatar
i just bought an o6 today and i was wondering how long i should wait to put a programmer on it (mileage wise)? also i was looking at the crazy larry would that be the best programmer out there for the o6 as far as a street application. thank you
Old 10-17-2006, 11:21 PM
pet05's Avatar
You will probably get quite a vast range of opinions. Do a search and a lot of information will appear. Just be careful with PRESSURE boxes as the injectors are touchy as is. Also, be careful of programmers that stress the transmission, as that can be a weak point.
As far as mileage, I think anything over 1,000 miles is OK. If the factory allows you to tow or haul thousands of pounds after 1,000 miles. You should be OK.
stock03's Avatar
I was thinking about a programmer, but I think I'll go with a module instead. They seem to be the most trouble free, and I don't like the idea of changing the factory program on my truck (which is what a programmer does).
Old 10-18-2006, 12:03 AM
lightening ram's Avatar
and what do you think a module does?????, cheats the factory programming.
Old 10-18-2006, 12:10 AM
stock03's Avatar
So what’s the difference? I thought the module acted like a ‘piggy-back’ does on a gas motor. And I thought the programmer erased factory settings with something new.
Enlighten me on this please. If your programmer is stolen (and your truck was set on one of the performance settings) how do you go back to stock?
If the module is stolen, your truck goes back to stock, right?
That’s why I decide to go to a module instead.
Old 10-18-2006, 01:06 AM
StrokeThisCTD's Avatar
Bullydog Triple dog all the way. run it on the 90hp performance setting and leave it there forever. runs awesome.
Old 10-18-2006, 07:20 AM
sawboywv1's Avatar
Diablosport Predator. Leave on performance setting. Save the Xtreme for DRY day. Looked into the BullyDog and the Diablosport is less $ for the same results with CUSTOM tunes optional!
Old 10-18-2006, 08:48 AM
Smokeman's Avatar
The data view feature on the diablosport is an advantage. The Bullydog triple dog doesn't do that but it does give you control over a whole bunch of accessory stuff on your 06 such as high idle enable, accessory on after key off timing, fog light operation with high beam, horn chirps on or off for different functions etc. Take a look at whats out there. Plus the Smarty is now available for 06 I think. Read, read and read some more.
Old 10-18-2006, 08:54 AM
Luken's Avatar
I would also look at the Smarty. Even tho I don't own one.... yet. There have been some really good results so far.
Old 10-18-2006, 08:55 AM
Luken's Avatar
Another selling point is its completely untraceable.
Old 10-18-2006, 09:37 AM
2-Stroke's Avatar
I like the TripleDog too... Its all a matter of preference, just do your homework and dont be in a rush to just slap something on there.
Old 10-18-2006, 09:47 AM
BlackSunShyne's Avatar
I let mine hit 5,000 miles, or a little over, and then I put on the Edge J/A. Just rolled over 35K this morning, and zero problems to report.
Old 10-18-2006, 02:50 PM
ptgarcia's Avatar
I added my Quad box at 1000 miles.
barngal6
07-05-2009 06:49 PM
mymaur
11-15-2003 06:58 AM
peanut
09-04-2003 08:26 AM
peanut
09-03-2003 02:15 PM
gunracer1
27
08-16-2003 01:34 PM
Quick Reply: when to put a programmer on
