pusher pump
pusher pump
I have searched and I find 12 different answers. I want to add a pusher pump to my 98 24v ctd. Seemes like most like the carter. What pump do I want and what else will I need to do this job completely.
thanks
thanks
I think alot of guys are using the holley blue with good results.Out of curiosity,what are your fuel pressure readings?I want to compare them with mine.I think I need a new LP.
my fp gauge is after the filter and I get 14 at idle 12 at cruise and I have never seen less then 9 at WOT. My LP is brand new.
Does the holley blue come with everything I need?
The holley blue is a fuel pump that is originally designed for gassers,but a lot of guys use them on these trucks.You need to supply all the hose and fittings,it's not a kit,just a pump.But that would be pretty easy to do.I don't have one but I hear they work good.Do a search in the perf. and accesories 1-2nd gen forum and you will get alot of reading on the holley blue.BTW,my fp readings are 13 idle,10 cruise,and I let off at 5 on WOT. not too good.A new lp goes in tomorow.A DD pusher kit is going in behind it.Thats Another thing you might want to look into,as another option for the holley. www.dieseldynamics.com
If installing something like a Holley you basically have to get everything you need and make a setup for yourself. I have a Black on the frame. Pic's in my gallery.
Big Smoky
03-23-2006 12:11 PM
midwestdually
15
12-17-2004 08:52 PM
