Pusher Pump And Fuel Filters
Old 06-27-2007, 12:59 PM
91rangerturbo's Avatar
What have people done for filtering the fuel. Still using the factory canister or are you running a inline filter??
when you relocated the lift pump and installed a holley blue or carter fuel pump on the rail with the vulcan line kit?
Old 06-27-2007, 01:04 PM
MeanGrn's Avatar
get the fass system and be done
Old 06-27-2007, 01:07 PM
I can get the same setup for half the price with a little research. 800 bucks for a fuel setup is too steep for me.
Old 06-28-2007, 11:58 AM
B-Peterson's Avatar
the fass that uses the stock fuel filter comes with a napa gold in line filter . the hole set up cost about 450 or so
Old 06-28-2007, 12:28 PM
newriverSpecon's Avatar
Go to Cummins. Buy a remote head, and an FS1000 or 1001 (one is taller you want the shorter). Install big lines. The filters will contian half again more debris, filters 5 micron at mid 90% (factory '99 only does low 80% at 5 mic) an 99% of 10 micron. Head cost me less then $30. Filters are less then $15.
I dumped the entire factory assembly since I do'nt need heat here.
Randy
Old 06-28-2007, 04:50 PM
Thanks randy that's exactly what i was looking for.
Old 06-29-2007, 08:13 AM
Actually I THINK, not positive, but the FF1000 &FF1001 are the same but without the water seperator. But I have never inquired about the filter ratings on them. The only advantage is about 1" shorter over all. Cummins can give you a the tech line number for Fleetgaurd and they are willing to give you with the info.
Randy
Old 06-29-2007, 08:25 AM
randy thanks for the heads up. i will call them today and get some more info. I will keep you updated.
cyawallac
02-28-2007 04:03 PM
Big Smoky
03-23-2006 12:11 PM
wrk24wheel
05-01-2005 07:18 PM
midwestdually
15
12-17-2004 08:52 PM
gandrews
01-18-2003 10:09 PM
Quick Reply: Pusher Pump And Fuel Filters
