Pusher Fans on an I/C Truck
Old 08-09-2011, 05:54 PM
grandscapesllc's Avatar
Anyone ever do this? Looks to me like there is enough room in there if the grill inserts were taken out , and the lip on the the back of those holes was trimed away , and make new panels out of expanded metal mounted flush against the back of the grill hole ? Done some measuring and it looks like a couple a 12" ers would mount up against the condenser. My A/C comp sure would love them!
Old 08-09-2011, 06:49 PM
deanhinsley1963's Avatar
Let me know if this works! Been thinking about it myself. PICS PLZ
Old 08-21-2011, 07:27 PM
Update!
Well, got the fans installed with almost no issues. Found them on fleabay for 40 bucks. They are 12" x 2.7" and rated about 2000cfm for the pair. Only had to trim off 1 mount clip for each one of the trim inserts off of the back of the grill and one off of the back of the inserts. So here are some pics, assuming I can figure out how to upload them The back of the inserts will need a 1/4" trimed away from where they hit around the fan motor, but other than that it was a very easy install
Pusher Fans on an I/C Truck-p8170105.jpg
Pusher Fans on an I/C Truck-p8170108.jpg
Pusher Fans on an I/C Truck-p8190119.jpg
Pusher Fans on an I/C Truck-p8190121.jpg
Pusher Fans on an I/C Truck-p8190116.jpg
Old 08-21-2011, 09:21 PM
I'll have more pics after I trim the 4 inserts but so far everything has bolted back up in the stock positions with no clearence issues! The a/c now works great at idle and cruise and I was able to put the lazy fan clutch back on
Old 08-21-2011, 10:30 PM
BearKiller's Avatar
Thank you for showing how you accomplished this.
Now I know for sure that it can be done; of course, that never stopped me before.
Old 08-22-2011, 03:10 AM
Thanks for the update let us know if the grille inserts still fit with pics. plz.
Old 08-22-2011, 08:39 AM
bryson711's Avatar
Did you remove the mechanical fan from the front of the engine? And are just running the electric fans? Or are you running both?
Sent from my DROID2 using Tapatalk
Old 08-25-2011, 08:44 AM
yes , the oem fan and clutch are back on. Engine cooling was naver a problem but a/c condeser cooling always was, never got enough air flow over the condenser unless I was running down the highway. Yesterday in 114 deg traffic the a/c was putting out 40 deg air!
Old 09-09-2011, 09:42 PM
Well finally got to the grill inserts last weekend. The inserts were too thick and would not go back into the holes all the way witout hitting the fans, so I had to trim about 3/8" off of the back of the inserts, but with some patience, a die grinder with a cut-off wheel, and a belt sander table, I got it done, and there is 1/4" clearence between the grill and the fans
Attached Thumbnails Pusher Fans on an I/C Truck-023.jpg   Pusher Fans on an I/C Truck-022.jpg   Pusher Fans on an I/C Truck-024.jpg   Pusher Fans on an I/C Truck-025.jpg
Old 09-09-2011, 11:48 PM
BearKiller's Avatar
LOOKING GOOD !!!
I still intend to do likewise to the wife's truck; but now, running with a pinned fan-clutch and that silly vacuum-operated heater-hose valve in the trash and a manual ball-cut-off valve in it's place, on the recent 100* days, she was seeing 30* at the vents.
Doing away with that heater-hose valve and replacing with a good manual valve made a tremendously huge difference in her A/C.
lvmknsmoke..
04-09-2009 03:47 PM
AlpineRAM
08-06-2003 02:06 AM
drecu
15
03-19-2003 07:17 PM
Javaluva
02-10-2003 07:56 PM
Quick Reply: Pusher Fans on an I/C Truck
