Pump Timing Recommendation
What's your recommendation to set the pump timing on truck no. 2 in signature?
I'll also be installing a No 10 plate and a 3K GSK.
p.s. I've got gauges.
5.5 mm or 15.5* would be where I would go..... Above this some trucks with your mods and a 215 pump will loose the headgasket. Besides no need to go any higher with no more fuel than is being injected, now if you add large injectors more timing will help.
Doug
Doug
I'll second Jetpilot's recommendation of 15.5. Mine is set there and it runs and starts fine. It's where Piers recommended as well.
By the way, if you do have an EGR, make sure that pipe doesn't touch the hood insulation. Can catch on fire!
Srigs
08-06-2003 11:23 AM
Srigs
05-13-2003 01:48 AM
