Pump Sprocket Nut Size (timing)
Will be doing KDP over the weekend, decided at last minute to check timing. In case it's off, does anybody know what size the nut is on the pump sprocket??
Any timing tips??? I will be using the dial gauge on the #1 delivery valve method. I don't have the delivery valve socket yet, I just picked up a magnet base and gauge, probably find TDC this eve and mark the balancer. Thanks, Kevin
Re:Pump Sprocket Nut Size (timing)
Thanks for the info, sorry I did not thank you sooner. Now all I got to do is find time to adjust the timing. It will be my first time and I am skeeerd!! Kevin
Clane
06-02-2012 03:31 PM
