Pulling the engine Question?
Old Feb 15, 2008 | 07:33 PM
rdavisDGM's Avatar
Can you pull the 24v engine with a regular 2 ton engine lift, and also what engine stand do I need for this engine? (engine stand lb rating) also are there any tips are thing I need to watch out for when pulling the engine?
2001 ram 3500 4x4 6 speed manual
Old Feb 15, 2008 | 08:01 PM
jrs_dodge_diesel's Avatar
2 ton lift should work fine. Engine plus all accessories (alternator, injection pump, etc) weigh a little over 100 lbs according to the manual. Can't offer any tips on pulling it, as I have never pulled one, sorry.
As far as an engine stand goes, get one that has at least four rollers, can handle a long, heavy engine.
Old Feb 16, 2008 | 09:05 AM
Ed ke6bnl's Avatar
a little more then a big block chevy at about 750lbs. I think you ment 1000lbs
Old Feb 16, 2008 | 11:05 AM
Ooops, yeah that should say 1100 lbs.
Old Feb 16, 2008 | 11:26 AM
ScottGregory's Avatar
Engine is at least 1,100 lbs. I used a 2 ton crane with no problem. The engine stand I used is rated for 1250 lbs. It broke. (lousy welds a pin) I rewelded it together properly and it holds now but is awfull springy.
I made up some wooden supports to hold the end when I work on it. This engine is very long compared to v8 and other engines making a huge lever arm for the pivit pin. I would not skimp on the stand.
Old Feb 16, 2008 | 01:52 PM
Tate's Avatar
They have stands that you bolt to the side of the block, instead of the rear of the block. Takes some of the leverage away. I just built a stand out of 4" channel that holds the engines in by the motor mounts. Just an FYI, the engine is still front heavy, and the mounts are at different heights.
skog8301
Aug 27, 2009 09:55 PM
mullercarl
Competition / Pulls / OffRoad
45
Mar 19, 2007 10:10 AM
Timmer
Dec 28, 2006 11:05 AM
Jambbii
15
Feb 22, 2006 02:22 PM
clc900
Dec 5, 2004 06:35 PM
