pulling doubles
Old 04-30-2008, 01:09 AM
stumpjumper's Avatar
pulling doubles
for those of you pulling doubles, what type of brakes do you have on your trailers and what brake controller? i just bought a 6x12 tandem utility trailer to put some quads on. it has brakes on one axle. just wondering if i can just run 7 wire to the back of the fifth and use the brake wire to power the brakes on the rear trailer? i have the prodigy brake controller, do i need a second one for the rear trailer??? it will be a total of three axles with brakes.
Old 04-30-2008, 07:12 AM
2006Mega's Avatar
you can use one controller to power both trailers but i would recommend a sperate controller. that way if something goes wrong with the last trailer you can get it back where it belongs.
Old 04-30-2008, 10:31 AM
TonyB's Avatar
Also get another set of brakes on the 2nd axle on the tandem trailer. It'll make slowing it down MUCH more effective. I'm waiting for a little extra cash before I add a set to my flatbed. I don't use it much and when I do, I don't load too much weight on. I just like the extra margin for when I do load heavy.
As mentioned, it may be a good idea to add a 2nd brake controller for the 2nd trailer. At least you'll be able to control it independently if needed.
Tony
Old 05-06-2008, 09:41 PM
dieselcamp's Avatar
Check your controller as some will operate as many as 4 axles with brakes, I think your Prodigy will work, it tells you in the manual or try a search.
Old 05-08-2008, 01:21 PM
i've wired up a second prodigy. i found that the atv trailer brakes will lock up at 4.5 volts the rv takes 11 volts. the atv trailer only weighs 2100 # with 2 full size quads and my sons little 50. yes the prodigy does work with up to 4 axles. but when i found the different voltage desire, i decided to add a prodigy just for good measure.
Rednecktastic
07-15-2008 01:56 AM
rebel05
07-08-2007 06:12 PM
RAMV
05-19-2004 07:31 AM
banshee
01-11-2004 09:03 AM
tobyw
02-14-2003 12:11 PM
Quick Reply: pulling doubles
