pryo probe leaking at compression fitting
Old 04-01-2006, 01:39 PM
sadlerb_98's Avatar
Question pryo probe leaking at compression fitting
I installed the ISSPRO fuel pressure, boost, and pyro gauges the other day. I tapped and placed the compression fitting into the manifold with the thermocouple probe in place. The compression fitting is tight but there still is exhaust escaping where the probe extends from the compression fitting. The compression nut is as tight as it will get. Any suggestions? I've emailed Dieselmanor and waiting for a response. I thought I would ask you guys as well.
I will post the pic here once it is approved...
Old 04-01-2006, 01:47 PM
Geico266's Avatar
Did you assemble the pyro correctly? There are two small pieces that "hold" the pyro. The ferrel and the seat. They need to be in the right order to seal it properly.
Old 04-01-2006, 02:01 PM
eric13's Avatar
Did you lose the ferrel (sp)? I did when I installed mine and it leaked until I got a replacement.
Old 04-01-2006, 03:21 PM
sadlerb_98's Avatar
Unhappy
I will have to check that out. Does the ISSPRO R683 Steel Compression Fitting come with one? I will have to find the instructions and see if it mentions it.
On edit: here is the pic
On 2nd edit:
Just went out to the truck and removed the thermocoupler and probe. No ferrel. I will call Dave Monday morning and order another one. Until then I will search the driveway.
thanks guys,
Bob
Old 04-01-2006, 07:47 PM
Geico266's Avatar
Don't over tighten them when you get it fixed. Hand tight and 1/2 a turn more.
Old 04-01-2006, 08:08 PM
caper's Avatar
I have some soot in the same area as your showing , I installed it a year or more ago cant remember whats inside , anyone have a pic of the farrel. I don't think mine has it .
Old 04-01-2006, 08:40 PM
caper's Avatar
Yep sure as poop theres nothing inside , I remember there was nothing else with it and seemed like a strange compresion fitting when installing it but said to my self that must be it because they wouldn't forget anything . Well where does one get the missing parts ?? Do I have to call isspro?
Old 04-01-2006, 08:43 PM
Geico266's Avatar
Pretty common thing to loose. It's a little bugger. Give Geno's a call, I'm sure they have them.
Old 04-02-2006, 08:47 AM
sadlerb_98's Avatar
caper,
I will call dieselmanor tomorrow. I will let you know what they say. I wonder if this is something that could be picked up locally?
Bob
Old 04-02-2006, 09:41 AM
infidel's Avatar
You should be able to get a ferrule from any autoparts or well stocked hardware store for less than 25¢. If they don't carry them separately buy a compression fitting and rob the ferrule from it.
If I'm not mistaken the Isspro probe uses a 1/4"
Old 04-02-2006, 03:49 PM
sadlerb_98's Avatar
infidel:
I got some at Home Depot. 3 for 90 cents. I am going out to see if they will fit. Thanks for the tip.
Bob
Old 04-02-2006, 04:40 PM
Geico266's Avatar
Originally Posted by sadlerb_98
infidel:
Bob
Don't use the plastic ones.
Old 04-02-2006, 05:00 PM
sadlerb_98's Avatar
Talking Exhaust leak fixed
Guys,
The leak is fixed!
Don't worry.... I used the brass colored ones. Worked like a charm. I only tightened a half turn like Geico266 said.
Thanks for the help!
Bob
Old 04-02-2006, 05:10 PM
caper's Avatar
I just got a brass one also 1/4 inch put it in and the nut still bottomed out and it still leaks (soapy water test) . Got mine out of a brass fitting that looks the same as the fitting on the pyro . Any thoughts/???
Old 04-02-2006, 05:51 PM
sadlerb_98's Avatar
I will have to go and recheck mine then. I just used spit . Be right back.
on edit:
The Ferrell is working: no bubbles. I did find however, that I had leaks at the base of the fitting. Another turn of the wrench fixed that.
thanks,
Bob
Quick Reply: pryo probe leaking at compression fitting
