Problems
Old Oct 22, 2004 | 12:06 PM
ramtd02's Avatar
Problems
K i will start by saying that i just had my LP and IP replaced under warranty...and i want too hook my comp back up (wire unpierced). The only problem i am having is....it seems that after the new IP and LP there is no more plug in for the chip. I looked all through the wires...but cant see it.
Has anyone else encountered this problem?
What else could i do?
Jon.
Old Oct 22, 2004 | 03:24 PM
BigBlue's Avatar
You mean the MAP plug and data sensor plug are missing? Or the plug you used to have on the VP44 for the comp?
Old Oct 22, 2004 | 04:35 PM
ramtd02's Avatar
The data plug for the vp44....the map is still there...but the other plug is gone!! Do you think they moved it...or removed it on purpose?
Old Oct 22, 2004 | 05:02 PM
BigBlue's Avatar
That's a new one on me. Never heard of them ever doing that before.
Old Oct 22, 2004 | 07:08 PM
MCummings's Avatar
Check to see if it's been squeezed ibnto a spot somwhere.
The fuel filter housing probably got pulled off.
They had a good deal of your motor dissassembled,, the plug may have gotten squeezed into somewhere it shouldn't really belong.
There is no way to "remove" it, without cutting it from the wiring harness. You should see atleast cut wires.
I suggest a more thorough search of the drivers side engine compartment.
Merrick
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
