problems
Old Jan 19, 2004 | 06:04 PM
lgi40's Avatar
problems
My 96 dog is not turning off. starts good but when you turn the key it keeps running . my truck is a dodge 3500 flatbed dump 12vturbodiesel. it has 95000 miles on it .thanks
Old Jan 19, 2004 | 06:27 PM
dieselcrazy's Avatar
maybe the fuel solenoid ?? just a thought
Old Jan 19, 2004 | 07:36 PM
dsljunkie's Avatar
DEFINATELY the fuel shut off solenoid. Pull the plunger down to shut it off, for a temporary fix. For a permanant fix trace all the wires and try to determine which wire is not recieving proper voltage or which is shorted out. May also be out of adjustment. The Fuel shut off solenoid is a VERY common problem with the 12 valvers so dont think your all alone on this. If youll just take it slow you will be able to get it licked.
Scott
BTW: How exactly have you been shutting the truck off?
Old Jan 19, 2004 | 10:30 PM
kandgo's Avatar
Start with cleaning the fuel solenoid,then the replace the relay on the firewall it is the one near the brake booster. www.fostertruck.com less than $20. Goodluck, Rick
Old Jan 20, 2004 | 10:50 AM
lgi40's Avatar
Thanks for the help . i have been turning the truck off by stalling in 5gear . thanks for the link also. the dealer said it would be about 600.00 to fix HA' .
Old Jan 20, 2004 | 10:59 AM
Palmetto_kid's Avatar
fostertruck.com
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
olgraybeard
Mar 24, 2003 06:32 AM
Dwight
Mar 18, 2003 08:14 PM
