Problems with Redline - HELP
Not sure if it's the Redline or APPS or what, but my redline will only fuel about 60% of whatever I tell it too. On 50% setting it will only fuel like 30%. On 100% setting it will only fuel about 60%. Checked APPS voltage and it was low at .3V. Adjusted it to .5 volts and got like 1% or 2% more but that's it. Anyone know what the full throttle position voltage is supposed to be on these??? I am only getting 3.5 volts and I am heading to Terre Haute, Indiana tomorrow for the Extravaganza and need to figure this out!!!!!!!
ANY HELP IS APPRECIATED!!!
Thanks,
Rodney
Thanks,
Rodney
Could I possibly not be getting 5 volts through the PCM to the APPS? I have not tried it yet, but then again, I don't believe I have a meter at home.
How are you measuring the 60%? What I means is, when you have it on 100%, how do you know it's only fueling 60%?
Are you getting any error or warning messages from the Redline?
Paul
Paul
It has self diagnostics/voltage readouts for the APPS and something else. It also has a readout that tells what percentage it's fueling and when it's fueling. At WOT on 100% setting, I am only getting around 60% output. No warnings or errors.
CumminsRedneck
10-13-2014 04:49 AM
usmcduncan001
18
09-28-2007 01:41 PM
