Problems with 2002
Old 08-16-2008, 02:35 PM
05Supersomker's Avatar
Problems with 2002
My buddy is having problems with 02 . He says he can be driving it and all of a sudden it has no power and then it suddenly comes back. Local shop where he is at put a scanner on it and they ended up putting a TPS and a map sensor in it and it still did not fix truck. Any suggestions??
Old 08-16-2008, 02:46 PM
2002-5.9's Avatar
Fuel pressure?
Old 08-16-2008, 02:54 PM
Floorman's Avatar
do it have any codes?
Old 08-16-2008, 02:57 PM
louddodge's Avatar
Sounds like a lp going out. Had a 2001 do something similar.
Old 08-16-2008, 04:27 PM
mishkaya's Avatar
Hopefully he has a fuel pressure gauge as they are a must on any VP44 powered engine. My bet is the VP44 though.
mishkaya
Old 08-16-2008, 04:29 PM
I don't know what codes it is showing. I talked to him a while ago and told him to check fuel pressure.
Old 08-16-2008, 04:36 PM
Old & Injecting's Avatar
I just experienced the same. 'Twas a slowly deteriorating lift pump that eventually caused the VP44 to eat itself at 67K miles. My mechanic had the same with his 2002 at nearly identical mileage. Installed the in-tank lift pump conversion and a new VP44.
DJ Turbo.
10-13-2011 09:11 PM
larsonstephen
05-21-2006 07:33 PM
greasemonki
17
10-19-2005 09:54 AM
mrpiano458nte
10-03-2004 08:21 PM
Jones0027
01-28-2003 11:01 AM
Quick Reply: Problems with 2002
