Problem
Old Mar 28, 2005 | 02:37 PM
CODODGE2500MAN's Avatar
Question Problem
So I'm driving down the highway and the truck seems to be doing fine. Then I went to pass a car and it tried to stall, then grabbed and threw us forward. Now when I hit the pedal even 50% it acts like i am pushing on the pedal, then lettin go, then pushing on it, then letting go. It has a horrible on/off feeling of the throttle.
I just had the tranny checked, and all is well, but could it possibly be a fuel problem or ? What do you guys think?
THANKS!
Old Mar 28, 2005 | 02:48 PM
latitud_rt's Avatar
Possibly the APPS? I guess resetting it may be worth a try.
Old Mar 28, 2005 | 02:55 PM
How do I do that?
Old Mar 28, 2005 | 03:10 PM
RowJ's Avatar
It's in the Tech Facts...in the header
https://www.dieseltruckresource.com/...n&onlynewfaq=1
RJ
Old Mar 28, 2005 | 03:16 PM
Since I just had to replace my batteries, this may be the problem. It might have gotten messed up when I was putting them in. I'll try her tonight. Anything else i should worry about?
Thanks a ton guys!
Old Mar 28, 2005 | 03:25 PM
HOHN's Avatar
With this kind of thing, it's either the APPS or the VP pump. Pray it's the APPS
Old Mar 28, 2005 | 03:37 PM
Why is that? How much is a new VP pump? and how hard are they to put in?
Old Mar 28, 2005 | 04:07 PM
BigBlue's Avatar
A new VP will run ya between $1200-1800. I've heard they aren't that hard to install but I dunno and I'm hoping I never have to find out (knock on wood).
Old Mar 28, 2005 | 04:39 PM
seabee's Avatar
if its a vp call the guys at www.cumminsstuff.com i hear that you can get a vp for under a grand from them .
Old Mar 28, 2005 | 05:44 PM
seabee
Do you know how hard they are to install? have you done it? did you get yours from them? Thanks a ton guys, I would be a nut w/o this place!
Old Mar 28, 2005 | 07:24 PM
rockwithjason's Avatar
Installing a vp is not that hard. You will need a large torx driver to change over the brackets on the vp. I recomend buying the factory manual as the procedure and all the particulars are in there. It took me about 3 hrs to change my first and that wasn't rushing.
CTD23
Jun 9, 2006 09:32 PM
Checkmate
Mar 5, 2005 08:36 PM
callum
Nov 21, 2004 07:04 PM
dogman
Dec 27, 2003 07:06 PM
