Problem With Boost Fooler
Old 10-17-2006, 10:03 AM
wimpy76's Avatar
Installed the boost fooler still only surging to 32psi and leveling off at 30psi.(SAME AS STOCK)
Has anybody else had this happen? My led light is coming on green so it should be working right.
Old 10-17-2006, 11:15 AM
qzilla's Avatar
If you can un-install the Flashpaq and see what sort of boost readings you get. I am wondering if a particular version of the Flashpaq is doing something weird and not fueling past 30psi or something?
On a bone stock truck the boost fooler should give you 38-39psi very easily. If it does not do that then there may be somthing wrong with the Boost Fooler. I would think if it was acting up then it should set a code though.
WE havea Flashpaq here and we can hit 45psi on the high setting.
Quad
Old 10-17-2006, 12:52 PM
wimpy76's Avatar
I will try that and let you know what I found out ....
THANKS
Old 10-17-2006, 04:01 PM
wimpy76's Avatar
qzilla
Put stock program back on truck and the results were the same 32 was the max. WOT flat ground 90mph still the same..
Old 10-17-2006, 04:21 PM
qzilla's Avatar
Sounds like we need to get you a new one?
Call tech support and tell them what happened and they will get one out ASAP.
Quad
Old 10-17-2006, 11:05 PM
roc155's Avatar
i just ordered the boost fooler on friday. i'm wondering how well it will work with the bdtd? anyone got any info with that set up?
Old 10-17-2006, 11:26 PM
qzilla's Avatar
It works great and a lot of people are using it.
I am curious to get this other one back as we have not had any issues with any of them until this one.
I am curious to see what did not work.
Old 10-18-2006, 06:47 AM
roc155's Avatar
qzilla i can't wait to try it and see. i'll give you the feed back once i get it.
Old 10-18-2006, 09:24 AM
wimpy76's Avatar
qzilla
Tried the boost fooler on another truck and it wasnt just mine. We seen the same results in his. But anyways called tech support and they said to send it back and they would check it. So it is on the way back today hopefully we will find something and I can get this thing back and get it running...
Thanks for all your help.GREAT customer service!!!
Old 10-18-2006, 09:27 AM
qzilla's Avatar
Shoot me a PM with your name so I can go in the system and get you a new one on the way today.
Quad
Old 10-18-2006, 11:07 PM
roc155's Avatar
qzilla and del.
all i can say is i should have been ordering parts from qzilla before. i ordered my boost fooler late friday night and paid for regular ground shipment and i got it wed morn. that is great service. i ordered some seat covers for my jeep 3 weeks ago from 4-wheel parts and still haven't seen them. i also wanted to add i talked to one of the guys here from dtr (the phone # is on the page about order discounts) and i forgot to get his name but he was one of the most helpful guys i've talked to.
Killdmycobra
11-12-2010 05:15 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
rkelley
19
01-11-2007 10:59 PM
GTSDave
07-08-2005 09:06 AM
Palmetto_kid
01-16-2004 02:21 PM
Quick Reply: Problem With Boost Fooler
