How is pressure increased indirectly?
Old 04-02-2007, 08:57 AM
trik396's Avatar
It was explained to me that pressure is increased indirectly on some of the Diablo Predator tunes. Can someone explain the difference between direct pressure increase and indirect pressure increases? I am totally confused by the indirect statement.
Old 04-02-2007, 11:37 AM
MikeyB's Avatar
The indirect method I believe is with the ECM raising the rail pressure due to the longer duration that's in the program. With the longer duration the rail pressure will drop and the ECM will compensate for the drop.
MikeyB
Old 04-02-2007, 01:13 PM
trik396's Avatar
So is the ECM doing this in stock programming or will it do this only if told to do so?
Old 04-02-2007, 05:10 PM
trik396's Avatar
Bump....
Someones gotta have a definitive answer...
Old 04-02-2007, 05:29 PM
MikeyB's Avatar
I assume it's with the programming algorithm. The ECM reads the rail pressure, and the longer duration at WOT the rail pressure will try to drop, and the ECM will compensate by increasing the pressure.
With the longer than stock duration that a programmer provides, obviously the rail pressure will go a little higher than stock.
MikeyB
Old 04-02-2007, 05:42 PM
trik396's Avatar
MikeyB, thanks for your replies. Do you know of anyone who would know absolutely? Maybe Quad?
Old 04-02-2007, 07:16 PM
MikeyB's Avatar
Quad or Marco should know.
MikeyB
roysleight
08-21-2010 10:01 PM
goffracing
03-01-2008 10:46 PM
beandrew
11-17-2006 04:10 PM
PADZZ
09-02-2003 03:46 PM
tobyw
07-28-2003 06:55 PM
Quick Reply: How is pressure increased indirectly?
