power steering must be on its way out???
I have had my 94 CTD since November of 2005. Has had a leak in the PS since day one. Now the steering is starting to feel like I have it in 4 wheel drive when turning sharp left or right. The steering box leaks at the bottom. So who makes a good after market steering box? What is the cost? And any tricks to the removal and install?? Thanks....
Dave
Dave
I'm running a PSC power steering box and I like it. Nice and stiff just like the factory. I don't remember the cost on it. Very easy to remove. Just unbolt it. The hardest part is getting the lines put back on because there's really no easy way to get to them.
heres the link http://www.pscmotorsports.com/index....d46e709fef78e0
Im curious what you guys that have installed the PSC gearbox and their sector shaft brace thought of the improvements, as well as how easy / difficult the install was.
Im probably due for a trackbar soon, maybe thuren or lukes link. Steering wheel doesnt point straight either.
Adjust your drag link to get your steering wheel straight, takes 5 minutes. Just loosen the bolts on the link and turn it right or left with someone in the cab telling you when it is straight.
The Thuren bar is nice for stock trucks with minimal lift but I would get the DT track bar if you have anything over 4" of lift. I welded my DT bracket to the frame and it as been running strong for over 5 years.
Joe
Rollin' Smoke
18
06-16-2007 09:58 PM
BigDave12768
12-14-2006 01:55 PM
