Power steering box problems..
Anyone here have problems with there power steering box top loosing. About every 2 weeks I was having power steering problems and kept adding more fluid until I found out the problem. The 4 bolts on top of the power steering box were loose. I tightened them down and all was good for about a month and then they worked loose again. I put a new gasket on and lock-tighted the bolts and everything has been cool for about 2 weeks.
Is this a problem on all these or am I just lucky
2001 CTD 3500
2001 CTD 3500
Re:Power steering box problems..
Smokedawg:
I had that problem a couple times myself and have heard of others as well. I just tightened them up and then about 6 months later it did it again. A couple of those bolts are hard to get at. Second time around I torqued em down a bit more and haven't had a problem since and its been about 2 years now. I think what you did should solve your problem.
What exactly is the power steering box? every now and then when i start up and take off the steering is hard. i wanna check mine now that we are talking about it, so where is it located?
When I replied earlier, I assumed "power steering box" just meant the steering box. If that is what you want to check, it is located in the drivers side front of your engine compartment, to the side of the engine.
I would check to make sure that your intercooler hoses are not rubbing on anything and that the clamps are tightened on all of your hoses. Some have had problems with the hoses rubbing and cutting holes in the hoses near the intercooler. I would also get gauges if the truck doesn't have them. Lift pumps are a problem on these trucks, so you definitely want a fuel pressure gauge. Many guys, myself included, also have an egt gauge and boost gauge.
Dean Snow
11-14-2007 04:36 PM
04ctd
10-05-2006 08:27 PM
LanceK
13
07-14-2006 08:08 PM
unioncreek
06-29-2005 02:00 PM
