View Full Version : Power Service vs Stanadyne (Round 1)
ATM2754
09-13-2006, 12:20 PM
I have been reading Forums in this fuel section for about 3 days now trying to find what the best all around single additive is and I keep hearing about the 2 Biggies which are Power Service and Stanadyne.
I want to hear everybodys opinion that reads this post, on what they run and why they run it, and any hard cold physical evidence of the benefits of running this stuff, especially in the long run.
I know that when I get my truck very soon, I will have a bottle of something in my hand at every fill up. Now DTR members, let me here your trials and tribulations for the best Fuel additive on the market, may the best Additive win!!!
dodgezilla04
09-13-2006, 01:13 PM
i've used both, depends on where I am shopping and how soon I need it. no noticeable difference. I know that PS is about $2 a bottle less than stanadyne.
surfram
09-13-2006, 01:52 PM
Power service is much easier to find locally where I live. I have been using it for 54,000 miles with great results. My truck always gets better mpg and runs quieter on PS. I'm sure that stanadyne is great also because my father uses it in his boat and it helped clear up some fuel system issues that he was having.
Jezzhuntin
09-13-2006, 02:03 PM
I run PS, I am sure it makes a little difference, but not really sure since i have been running it since day 1. Hard to tell, but neither can hurt.
dodgezilla04
09-13-2006, 02:29 PM
i notice a difference with and without using treatment, just not between brands. I put 10k on it before I got smart. Without using treatment, if it had been a few weeks since pulling the trailer, the injectors and motor would be louder, and run rougher, after pulling all of the junk had burned off and all is well. now using treatment, it never gets junky.
shep1
09-13-2006, 03:00 PM
I'm using Stanadyne only because that is the only fuel additive that my Dodge dealer sells. I did use the p/s-mmo mix for a while. I'm sticking with the Stanadyne because it is approved by other truck builders (no names) and it is sold at my Dodge dealer.
My service tech said there will never be an issue with the warranty using Stanadyne and Truck runs smoother and quieter with it.
XLR8R
09-15-2006, 01:25 PM
Power Service Silver because it's cheap, readily available, and definitely makes a measurable difference. [guitar]
Of course, I do cut it with acetone...
06dually
09-16-2006, 12:17 PM
Stanadyne.....Why?? Because I get it for free!
carcrz
09-16-2006, 12:38 PM
Power Service & MMO
Shovelhead
09-16-2006, 12:46 PM
Stanadyne PF
I buy it in the 5 gallon pail from the local Diesel Injection Service shop. (~$145.00)
Compare the brands:
http://www.stanadyne.com/new/ppt/showfile.asp?id=1156
MikeyB
09-16-2006, 01:12 PM
I use Power Service since it's much easier to find. Walmart and Tractor Supply Co. is my two sources.
MikeyB
Danderson
09-16-2006, 05:07 PM
I've used Standyne or P.S. in my Dodge for seven years now. Conversely,I've driven a '92 Hino four cylinder cabover for 230,000 miles. It's never had a drop of additive and runs like the day it was assigned to me. Allison auto has been trouble free too. Toyota's coming out with their fullsized truck in Feb. I hope Chrysler wakes up and starts honoring their warranty and researching their products more thoroughly,thus avoiding warranty claims. We want to buy American and our companies need to give us a reason to support them. Pardon my rant and now back to your regularly scheduled program.:cool:
Forget those, do your truck a favor and use Fuel Power:
www.lubecontrol.com
capt.Ron
09-16-2006, 10:24 PM
I've used Howes and P.S. and I could only see a significant difference using the Howes.
infidel
09-17-2006, 11:55 AM
My feeling is they all come out of the same barrel...
marv h.
09-29-2006, 10:22 AM
Ok, but do you think they help any, or enough to use on a regular basis.
infidel
09-29-2006, 07:35 PM
Ok, but do you think they help any, or enough to use on a regular basis.I don't think additives are needed at all on a 12 valve except for winter anti-gel. That's all I've ever done with a problem free over 200k on both my rigs.
Now the 24 valves are a different story, they need all the help they can get.
Begle1
09-29-2006, 07:38 PM
12 valves including us of The Lord's Pump (i.e. the VE)?
I just used some Power Service for the first time to make sure the new ULSD doesn't have any problems; stunk terrible for a few miles, but now I have less smoke and it runs quieter, and I figure it can't hurt the fuel-lubricated pump.
(And has anybody else ever inhaled this stuff? Cawhewie! It feels, like, thick when you inhale it. It's like you can drown in the stuff!)
wannadiesel
09-29-2006, 08:00 PM
The VE is fuel lubricated like a VP44. A fuel additive is a very good idea, especially with a turned up pump.
The P-pumps on the later 12 valves are lubed by engine oil.
XLR8R
09-30-2006, 12:30 AM
I just used some Power Service for the first time; stunk terrible for a few miles, but now I figure it can't hurt.
Don't worry, Begle - it grows on ya: I've been huffing PS silver out of a paper sack for years... I actually got my common rail so my P.O. wouldn't wonder why I was spending so much on "additives" [tapdshut] [laugh]
j-dubya
10-03-2006, 07:08 PM
i use power service, but have never really noticed a difference using it and not. what volumes are you guys using?
jeremy
Mountaineer
10-03-2006, 07:17 PM
HOWES gets my vote.
Lee S
10-10-2006, 04:53 PM
Been using Stanadyne PF pretty consistently since the first tankful. I've also tried Power Service a couple of times and it seems to be okay but I've got 2 cases of Stanadyne in the storeroom so I'll stick with it. I also put a glug or two of Marvel Mystery Oil every couple of fillups.
Last fillup, I didn't use any additives at all. What difference does it make? The engine runs a little noiser for one thing. The biggest difference has been the mpg. Whereas I usually get 15.5 to 16.5 around town, I'm now getting 14.8 by the computer.
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
