Power Service Diesel Kleen...Helping?
Old 07-29-2011, 05:30 PM
Received 1,331 Likes on 862 Posts
Well I've been having issues with hazing and white/blue smoke, right from start up and through to running at temperature. I've been running 2 cycle oil, and a touch of Howes as my fuel additive since I started driving the truck.
Well I decided that I would run out my 2 cycle and Howes and then switch over to "Power Service Diesel Kleen + Cetane Boost" additive. Since a ot of the people who run it here on the DTR seem to have good things to say about it.
Well I did one tank and didn't notice much change, but then last week when I went to pick up my friends 63 Impala I figured this would be a great time to have it in the fuel to help clean things when it's running hot and steady on the highway.
Well I've noticed a huge reduction in my hazing, and when I'm driving off from a stop sign or light, I'm not getting that cloud of grey/white smoke at lower RPM's.
Not saying this solved my problems, but it sure seems to have helped.
Old 07-29-2011, 08:57 PM
Jklawinsky's Avatar
Good info.. I've been thinking about trying with the 2 stroke I use as well.
Old 07-29-2011, 09:16 PM
1STGENFARMBOY's Avatar
Thanks COW .....i had some of that in my hand today but couldn't pull the trigger.
i have a hazing problem also and it is sooooooo anoying.
i think i will try it also
Thanks Dar
Old 07-29-2011, 09:24 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
I've noticed a little better milage to when I;m running it.
Old 07-29-2011, 09:32 PM
I'm still convinced I have at least one bad injector, maybe two, since I get a puff of black smoke when I first take off. When I'm giving it the loud pedal it will puff black smoke irregularly, not the constant smooth rolling of black I've seen from most vids of 1st gen trucks givin' er.
But I'm pretty happy with the power service additive so far.
Old 07-30-2011, 07:49 AM
Moparbubba's Avatar
Ole shakey likes it gets a little better mileage and less smoke
Old 07-30-2011, 03:28 PM
bulltamer's Avatar
i put it in my last tank and it seemed to boost mileage a bit and my truck runs a lil bit better
Old 07-30-2011, 03:55 PM
RonA's Avatar
My truck starts hazing when my pop off pressures get low(takes about a year or so). If I bump them back up, it goes away. Not sure if VE stuff is the same.
goose2
06-01-2006 05:23 PM
jlells01
23
10-30-2004 09:36 PM
jrs_dodge_diesel
01-06-2004 09:13 PM
Chrisf
08-22-2003 12:03 PM
redramnc
06-10-2003 05:58 PM
Quick Reply: Power Service Diesel Kleen...Helping?
