power puck and flux 1's?
when I first got my truck, I ran the predator and puck combo. naturally my injectors went south (stock injectors). So I disconnected the puck and installed flux 1's. ever since then I have just been running the predator on "performance" and kept the puck off. will the flux 1's be fine with the puck and predator on? or should I just play it safe and keep it off?
DTR 1st Sergeant
I run a puck as well and with flux 3's. It doesnt matter what nozzles you are using, running pressure all the time will shorten injector life.
What I do is leave the puck off until I am at the track or dyno... or unless I need to pass someone, then turn it back off.
The puck can be aggressive, so use it judiciously. Even when otherwise running stock pressure settings (smarty/TST) I can see 27k when I turn on the puck.
thanks. I dont really need the added puck power, the predator does just fine. I think I will just leave it off. save myself $1500 later down the road.
bradler
02-18-2009 12:43 PM
OldSmokey
19
03-26-2008 05:11 PM
metal_miner
52
06-23-2007 02:52 PM
O.T
05-30-2007 08:55 PM
MoparRiggan
01-10-2007 03:31 PM
