Power Gains From A Boost Fooler
Old 04-03-2006, 06:44 PM
edy
edy's Avatar
Is there any power avantages with the boost fooler plaes let me know.
Old 04-03-2006, 07:12 PM
graphitecumnz's Avatar
A boost fooler is only necessary if you're using power adders; i.e. chips, boxes, injectors... and most electronic power adders have a built in boost fooler.
All it does is fool the ECM into seeing less boost than the stock programming is limited too which is only an issue when you start adding fuel at levels above stock.
Old 04-03-2006, 07:17 PM
ib516's Avatar
...and the Superchips programmer doesn't have one built in like amny "boxes" that plug in and stay under the hood do such as Edge EZ or VA.
Old 04-03-2006, 11:59 PM
Ph4tty's Avatar
Try disabling the wastegate first. If you can push enough boost to trip a p0234 code then you need a boost fooler, smarty, ez, va,..
Old 04-04-2006, 10:18 AM
high country's Avatar
get the fooler and hook the wasegate, even at stock fueling you can benefit from the extra boost, while it may not be a 20 psi gain when you bury the throttle on a long pull it will help with the power and temps. with just the superchips and a fooler using the hook you should see 25-27psi at wot
Old 04-04-2006, 11:30 AM
seabee's Avatar
i was offered a set of 120s last night at a price i cant refuse i was wondering if just the sticks and a boost fooler would be fine . or am i looking at way out of hand egts with this little hy
Old 04-04-2006, 12:17 PM
you will be all right if you have an egt guage, low rpm's and heavy pedal/big load-hill might warm up, but if you rev it you'll be fine. I have a friend with 130's and no fooler and he does ok just grab a gear on the hard pulls and watch your foot. that said, a timing box is only gonna help your egt's and mileage.
Old 04-04-2006, 12:23 PM
RustyJC's Avatar
A boost fooler will only allow you to run at higher boost levels - the more boost, the more mass airflow (although the incremental mass flow becomes less as boost and compressor discharge temperature increase). Unless you are overfueled, more boost will not produce more power.
What a boost fooler does is provide the air necessary to burn additional fuel more efficiently (i.e., with lower EGTs and less smoke). The additional fuel is what produces the additional horsepower.
Rusty
nsd22002
03-11-2011 12:37 PM
Killdmycobra
11-12-2010 05:15 PM
arcticcat12224
09-10-2007 05:01 PM
Tron
09-08-2007 09:04 PM
Rollin' Smoke
23
06-26-2007 09:04 PM
Quick Reply: Power Gains From A Boost Fooler
