Power to the fuel pumps...?
Old 09-06-2009, 06:53 AM
dodge-dodge's Avatar
I'm cross posting this from the help - as over there no response for 24 hours, maybe someone over 'here' can help.
Vehicle:
2005 Dodge Ram 2500 (Diesel of course)
None of the fuel pumps are getting power - neither are the gauges when the engine is turned to on.
No animal chewings, and tested the fuses and relays and everything seems to be checking out. The socket for the fuel relay (may be worded different slips my mind not looking at it) one hole reads 12 and hte other 6 on the voltage meter - is this correct? My other truck is reading 12 and 12 from both holes but is a gasoline.
Tried to hook up a check engine light scanner - can't read anything not able to connect, "error". Tried the on-off-on-off-on with the ignition and not coming up with any codes there either.
At a real lose and would appreciate any further insight. The truck did sit for 3 weeks without being started as had to leave the country in for an emergency but didn't think this would happen.
Also lightly sprayed ether into the air intake and it tried to start up but choked out immediately.
Both batteries are charged fully.
Old 09-06-2009, 07:32 AM
John Faughn's Avatar
A couple things to check , fusible links at batteries , ASDR = auto shut down relay .
Then the long list of ground connections .
Old 09-06-2009, 02:57 PM
corygale's Avatar
sounds like a bad ground
JJK98CTD
03-29-2009 10:45 AM
BigBlue
05-13-2007 12:31 PM
Ilikebikes
12-11-2006 10:13 PM
jesterstruck
11-23-2006 01:53 PM
BigBlue
05-10-2005 07:55 PM
Quick Reply: Power to the fuel pumps...?
